posting question on main vpl thread.
AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Should I buy Sony VPL-VW95ES
Featured Stories
Topics Discussed
Related Forum Threads
- Sony VPL-VW95ES plus 2 pairs of 3d glasses Last post on 5/3/13 at 1:55pm in Display Devices
- New SONY 1080P SXRD Projector 04 2013 the successor of the VW95ES Last post on 2/19/13 at 10:11am in Digital Hi-End Projectors - $3,000+ USD MSRP
- Sony HW50 vs VW95 Last post on 10/11/12 at 6:53am in Digital Hi-End Projectors - $3,000+ USD MSRP
- Scratch that Panasonic PT-AE8000 or Sony HW50ES, how about Sony VPL95ES or Mits HC9000D? UPDATED:... Last post on 9/27/12 at 7:30pm in Digital Hi-End Projectors - $3,000+ USD MSRP
- Official Sony VPL-VW95ES Owners Thread Last post on 5/20/13 at 2:27pm in Digital Hi-End Projectors - $3,000+ USD MSRP
Related Reviews
Should I buy Sony VPL-VW95ES - Page 3
- « Previous
- 1
- 2
- 3
- Next »
Gear mentioned in this thread:
post #62 of 74
12/18/12 at 10:10am
- DTGallagher
- Trader Feedback: 0
- Appreciative Lurker
- offline
- 189 Posts. Joined 11/2001
- Select All Posts By This User
Probably too late to chime in here - but I have a VW95ES and I find it much too dim for 3D - even at 110".
Another thread over on the 3D Display Forum provided a spreadsheet which implied that I wouldn't get any additional
impact from a Dalite High Power screen since the screen I'm presently using (an old Stewart Firehawk with 1.3 gain)
maintains polarization to the point where I'm actually getting more gain from the Stewart than from the Dalite.
(I don't really understand any of this; I just have to trust the numbers.)
Anyone care to convince me that the spreadsheet calculations are incorrect and that the High Power screen WOULD make a difference? (I have a small sample and the image projected on this sample DOES look brighter than the rest of the picture. The rest of the picture also looks gray in comparison to the High Power (which I would expect from a gray screen designed to increase perceived contrast from low contrast projectors like the Infocus 7200 which I was using when I purchased the screen.)
Edited by DTGallagher - 12/18/12 at 10:22am
I'm getting my screen on Thursday. Will let you know how 3D looks on it at 110". How dark is your room????
Also can you provide link to spreadsheet from 3D forum.
post #64 of 74
12/18/12 at 1:43pm
I can't comment on the Stewart Screen but the closer you mount the Dalite HP screen to eye level the more gain you get. The easiest way to determine if it makes the picture brighter is to call Dalite and ask for a screen sample. I would request a 12x12 sample otherwise you'll get a much smaller sample.
post #65 of 74
12/18/12 at 1:48pm
- Ron Jones
- Trader Feedback: +1
- offline
- 5,008 Posts. Joined 7/2000
You only get an effective gain boost for 3D from a screen that retains significant polarization if the 3D projector has all 3 colors with the same polarization orientation. This is the case for JVC projectors, but not Sony SXRD projectors (e.g., your VW95). As for the Da-lite high power, it can potentially give high gain (eg., near its rated 2.4 gain), but only if it is mounted near eye level or only a modest distance above eye level.
post #66 of 74
12/18/12 at 4:57pm
- DTGallagher
- offline
Fairly dark but not bat cave dark. I have dark side walls but keep a couple of wall sconces on at low level.
http://www.avsforum.com/t/1300238/discussion-screens-for-3d-projection
Zip file is included at the end of the initial post in the thread.
Edited by DTGallagher - 12/18/12 at 5:24pm
post #67 of 74
12/18/12 at 5:09pm
- DTGallagher
- offline
I see that you're the originator of the 3d projection screens thread - and I assume of the speadsheet I referenced. I entered a screen gain adjustment of 60% based upon the percent of polarization maintained by the
Stewart screen cited in the initial post of the thread. Are you saying this number doesn't apply based upon the type of projector I'm using? This is much too complicated.
I believe the type of glasses is also factored into the mix. I'm using mostly PS3 glasses since they're relatively cheap.
(I have one pair of Monsters but consider them more trouble than they're worth having some difficulty turning them on and syncing them
with the projector.)
If the polarizatiion adjustment is actually "0" for the Sony/Stewart combination I'm back to considering the High Power screen since it should give me a brightness
of 10.6 fL versus 7.2 for the newly calculated Sony/Stewart combo.
post #68 of 74
12/20/12 at 5:23am
i can't say that it will be bright enough for YOU, but i have a 133" 16x9 Hi Power 2.4 screen. My VW95 is mounted about 4 feet above my head, at mid throw, 15 feet. The pic is plenty bright for me in 3D. No complaints. But maybe you want your picture much brighter, i'm not sure. But my setup works wonders for me.
I saw Hugo 3D on my 130" Steward screen with my wife and then later another friend. None of us felt that the screen was dark. Put it this way. If I didn't know that people are having issues with darkness in 3D over 100" size, I wouldn't know of this issue by just looking at my screen. My projector is mounted at 18 ft from screen.
And my I say that it completely blew my mind away. The 3D was amazingggggggggggggggggg. I couldn't believe it. I read in many forums that 3D is good but didn't expect to be this awesome.
And 2D. Well for me it couldn't get any better. So far only my wife and one of my friend have seen it and they both said that the quality is even better than of theater.
I couldn't ask for more. Yesssssssssssssssssssss.
post #70 of 74
12/24/12 at 7:49am
- A.West
- offline
- 116 Posts. Joined 6/2010
post #72 of 74
12/24/12 at 8:55am
- A.West
- offline
post #74 of 74
12/24/12 at 1:38pm
- A.West
- offline
- « Previous
- 1
- 2
- 3
- Next »
Back to Forum: Digital Hi-End Projectors - $3,000+ USD MSRP
- Should I buy Sony VPL-VW95ES
Currently, there are 1661 Active Users
(380 Members and 1281 Guests)
Recent Discussions
- › Official Sony KDS-XXA3000 OWNERS THREAD! 5 seconds ago
- › Master Burn-In/IR/Break In Thread Part II: All Posts Here Only 1 minute ago
- › Disadvantages to Plasma? 1 minute ago
- › Official Samsung PNxxF8500 Series Discussion Thread [No Street... 2 minutes ago
- › Calling all Polkies:Official Polk thread 2 minutes ago
- › >>Sony KDS-XXA3000<< Settings/Tweaks thread - OWNERS ONLY! 3 minutes ago
- › The **OFFICIAL** DENON AVR-4520CI thread 3 minutes ago
- › help looking for a new receiver 4 minutes ago
- › Official OPPO BDP-103 Owner's Thread 4 minutes ago
- › great white balance but primaries a bit off. 5 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › InFocus X1A DLP Multimedia Video Projector by coastercard
- › BenQ W1070 1080P 3D Projector by arjjr
- › Epson PowerLite Home Cinema 8350 by Natros
- › Epson V11H501020 PowerLite Home Cinema 3020 2D and 3D 1080p Home... by sailorb
- › Elite Screens ER110WH1 Sable Fixed Frame (110" 16:9 AR) by DDT0C
- › Elite Screens ER100WH1-A1080P2 Sable Fixed Frame Projection Screen by DDT0C
- › Peerless PRG Mount, Black by DDT0C
- › Epson 5020UB Powerlite Home Cinema 3D Front Projector by DDT0C
- › Sony VPLHS20 Cineza Digital Home Entertainment LCD Projector by varkeast
- › JVC DLA-RS45 Home Theater Projector 1080P HDMI by jmccarei
View: More Reviews
New Articles
- › Projector Review Contest by Nick Val
- › "List Your Gear to Win Some Gear"... by Nick Val
- › Most Economical Thin Client PC`s from RDP... by RDPThinClients
- › Media Browser 3 Announced by xzener
- › AVS Guide to Media Servers, Part 1 by Scott Wilkinson
- › Join the AVS Team! by Nick Val
- › 25 Top Blu-ray releases for 2012 by Ralph Potts
- › Sony Launches 4k Ultra HD Flat Panel - AVS... by Scott Wilkinson
- › Clarus Power Cords by Good Tunes
- › A Theater Is Just Is Not A Theater, Unless... by David Bott
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About AVS | Join the Community | Advertise | Contact Us
© 2013 AVS is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
