AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Projector Wall Mount Question (For 8500UB)
post #1 of 3
Well to start off, I'll be ordering my first projector tomorrow, a refurbished 8500UB. Now in my particular room situation a wall mount would be extremely handy, more-so than a shelf as it is going to need to sit out decently far. However the question I have is, are there any wall mounts in which you can have the projector upside down so the arm is supporting the projector like a shelf rather than having the projector hanging as you would traditionally with a wall mount? Thanks! Also, budget of less than $100 would be welcomed!
post #2 of 3
BUMP, Anyone? Any help would be massively appreciated!
post #3 of 3
All of the wall mounts i've seen support the projector from the top. Why do you want it the opposite way?
