I've been looking for hours about the proper setting for Klipsch RW-12D. I though there was a thread talking about a few different settings to try and see, which one works best, but I can't find it.
My current set up:
AVR: Onky HT-R960 (will be replace in a few months)
Front: Monitor 70's
Center: Klipsch synergy 1 (Polk Audio CS2 will be on order next month)
Surround: Jamo S426 (towers pair)
Surround back: Pioneer BS21 (pair)
Sub: Klipsch RW-12D
Sub current settings: Volume at 60%, Crossover 120 hz, Phase "Punch, at 180 deg.
I ran Audyssey, and the dB's is at -15 db in my AVR. I am going to lower the volume for the sub, and run Audyssey again to try to get the AVR's dB's close to 0 dBs as possible. However, I am not sure what to do with the subs crossover? Turn it off and let the AVR do all the work?
If anyone else has the same sub as me, what settings are you using. Thanks.
My current set up:
Front: Monitor 70's
Sub: Klipsch RW-12D
