AVS › AVS Forum › HDTV › HDTV Technical › Maximum Antenna on a J-Mount?
post #1 of 2
I'm looking at putting up a Winegard 8800 antenna + preamp + Rotor on my roof, and am thinking a J-mount is a cheap and simple way to go. But I can find no technical details about maximum windload for these things, or maximum recommended antenna size. I'm thinking that a dish, being a large, solid object, would have much higher wind load than a large bowtie UHF antenna, but I'm willing to be wrong. Anyone have any advice or specific information about J-mounts for antennas?
post #2 of 2
A rotor will be too much weight for a J-mount. I used an existing J-mount for a "turnstile"-type FM antenna once and it seemed successful (no movement, no roof leaks) and if the bowtie antenna were the same weight as that, no problem. Rotors, though, are heavy.
  Back to Forum: HDTV Technical
