I'm planning my installation and came across this product and wanted to get the communities feedback. I have a Epson 8350 that I'll be mounting to the ceiling and will also have a ceiling mounted outlet that it connects to. Therefore, my PJ is unprotected and not going to a surge protector. The Monster Flatscreen PowerProtect 200 is low profile and intended for flatscreen tvs put would work nicely for my application.
let me know your thoughts - i can pick this up for 13 bux. its not really about the costs more about whether its functional and perhaps it may be beneficial to others on the forums.
here are the features:
Features
Overview: The Flatscreen PowerProtect 200 surge protector mounts directly to a dual wall outlet. It is equipped with two AC outlets and a coaxial input and output.
SurgeGuard: The SurgeGuard circuitry features high capacity protection (1,100 joules) against performance-damaging power surges and spikes. It also prevents power disturbances from traveling down the coaxial cable connection to other home theater components.
24k Gold Contacts: The 24k gold plated coax contacts maximize signal transfer and corrosion resistance.
Dual Mode: Dual Mode disconnect circuitry also protects against secondary surges and spikes.
Coax Input/Output Terminals: The unit features two threaded coaxial connectors (1 input/1 output) on the bottom panel to protect your equipment from surges on the coax line. They are compatible with cable, antenna, or satellite signals.
Mounting: The Flatscreen PowerProtect 200 is designed to be used with a properly grounded, dual three-prong 110-120V AC outlet. It plugs into the top outlet and a plastic post slides into the ground opening of the bottom outlet
Features
