Build Updates on 11/27/12 Current Options to be reviewed
Ok here is the new Builds I've thrown together today
For both Options
Case - SilverStone GD04 Usb 3.0 (Black) - $122 with shipping
http://www.google.com/aclk?sa=l&ai=CPcIlrBa1UJHxFOya6wG8r4GwCfmotdQCqeywqELR1sKAlgEIBhABUL7O8ZYBYMm2uIzUpKgQmAHT8gegAeKNs_8DyAEHqgQlT9AtRMvdHmOG-nMgykUZNofxUwkVYXUU0nOGJi8It9baAWYuOLoFEwjz1tmJ8--zAhXlXjQKHYFvAGrABQXKBQCgBibgEozY1-bpg9jL0wE&ei=rBa1UPPQEeW90QGB34HQBg&sig=AOD64_1yH8T2wKhDmLTcHvA7oXHmmYLZUA&ctype=5&sqi=2&ved=0CJ0BEPQO&adurl=http://www.newegg.com/Product/Product.aspx%3FItem%3DN82E16811163179%26nm_mc%3DKNC-GoogleAdwords%26cm_mmc%3DKNC-GoogleAdwords-_-pla-_-NA-_-NA&rct=j&frm=1&q=silverstone+gd04
Power Supply - Rosewell Green Serise 430w - $55 with shipping (Not sure if that is able to be used on this case the other one I found was a Istar usa 400 w for almost double the price)
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CDAQFjAA&url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16817182202&ei=uBy1UPmhEKyF0QHgxoDAAg&usg=AFQjCNErwyy1mSGfTBak2ugj0Fuun3cK2Q&sig2=hRbJcrc31OHNpCaWeXEvlw
RAM (4gb) - 2x 2gb - G. Skill DDR3 1333 - $20
http://www.google.com/aclk?sa=l&ai=CS4-5BB61UKOcFO7j6QH2lICwCMmutdQC2ejDjUmZr4eClgEIBRABKAVQsdeb4vr_____AWDJtriM1KSoEJgB1PIHoAHijbP_A8gBB6oEJU_QTyxtLjgLo4M_3xNEW5BfjdgViUFZ5nDkkYeoJHYXwyowPQXABQWgBibgEpLZj6CZz7T_twE&sig=AOD64_3CmnWuBbuSHvNU6QSKZjqr5dA1ww&ctype=5&ved=0CC8Qww8&adurl=http://www.newegg.com/Product/Product.aspx%3FItem%3DN82E16820231252%26nm_mc%3DKNC-GoogleAdwords%26cm_mmc%3DKNC-GoogleAdwords-_-pla-_-NA-_-NA&rct=j&frm=1&q=g.skill+1333+desktop+memory
Wifi - RoseWill PCI - $22.98 (or would a usb stick be a better option?)
http://www.newegg.com/Product/Product.aspx?Item=N82E16833166033
Hard Drive - WesternDigital Green WD10EZRX 1TB - $72.97
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CFoQFjAA&url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16822236070&ei=ICi1UL-SLqqK0QGlqIHgAQ&usg=AFQjCNHxXWr8t9L3y8RkEeJ-A44zHIT6RQ&sig2=vtfmtl4i7IJDSCTvdtbkLw
Disc Drive - Lite-ON black 12X BD-R - $54.99
http://www.google.com/aclk?sa=l&ai=C97-vYyi1UJWvIcf36AHztICoDZmQ79IC0cLumBrprtvufggGEAIoA1Cxs8aWBmDJtriM1KSoEJgB0_IHoAHijbP_A8gBB6oEJU_QtuXd4gHE4uzOIJ6jskJpjE57w45s1X72sfl-d1zzi0kMRsjABQWgBibgEqLL4tHd57KImQE&sig=AOD64_1PRDN5e1Jm_cQoxwald-xjIgzaTg&ctype=5&ved=0CIYBEPQO&adurl=http://www.newegg.com/Product/Product.aspx%3FItem%3DN82E16827106369%26nm_mc%3DKNC-GoogleAdwords%26cm_mmc%3DKNC-GoogleAdwords-_-pla-_-NA-_-NA&rct=j&frm=1&q=what+disc+drive+can+play+3d+blu+ray
Sub total - $347.94
Option 1
CPU - Sandy Bridge Lgall Intel I3-2105 - $104.99
http://www.google.com/url?sa=t&rct=j&q=&esrc=s&frm=1&source=web&cd=1&cad=rja&ved=0CEUQFjAA&url=http%3A%2F%2Fwww.newegg.com%2FProduct%2FProduct.aspx%3FItem%3DN82E16819115090&ei=Px-1ULbtE6nI0QHK94HQBw&usg=AFQjCNGkP-kGpYfP7maVfAc_fPmyqJlUow&sig2=Yzf9wYhCqjyUcywvq1NN6w
Motherboard - ASUS P8H67M-EVO - $124.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131710
Totaling @ $577.92
Option 2
CPU - Ivy Bridge I5 3570K Quad Core - $219.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Motherboard - ASRock Z77 Pro4-M - $125.11
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157306
Totaling @ $693.04
Feel free to make any suggestions and or corrections to my builds. Thank you an critique away.
Original POST
Hi to start,
This is for a friend she wants to spend about $500 on it she already has the 3d tv and the sound system. I'm thinking only 8g dd3 ram should be good and I'm not sure which motherboard or tower to use.
For a Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813135288&nm_mc=OTC-pr1c3grabb3r&cm_mmc=OTC-pr1c3grabb3r-_-Motherboards+-+Intel-_-ECS+(EliteGroup)-_-13135288
For a processor I was looking at
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116399&Tpk=G620
For Ram
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231643&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&AID=10446076&PID=4176827&SID=2obfq6urkt8x
I'm wondering if that is strong enough to play 3D
Things that don't need to be included with the build is a remote keyboard or Windows. I'm looking for at least 2 docking stations in a tower that not sure if the compact HTPC Case is the way to go or A Mid size tower any help would be nice I have more parts that I've been looking at but I'm hoping for feed back and help before I set my own list in stone or post them up here.
I'm also wondering if I should use a dual harddrive method with one solid state with the Operating system, an a large slave or just one large harddrive.
Thank you sorry if I wasn't great a posting this I am new to this site.
Edited by SilverFoxhound - 11/28/12 at 7:30am
