AVS › AVS Forum › Audio › Speakers › Please help to setup a home theatre !!
post #1 of 22
Hai guys..,
I'm in a lot of confusion about choosing home theatre & receiver (5.1)
I've searched everywhere to find a decent setup..
Also buying 3dtv of sony (46hx850) with 3d player..
want a good decent setup for the tv !!
My receiver budget : around 200$
Home theatre : 500$
Currently iam thinking of these >
Denon AVR 1612 (199$) with energy take classic 5.1
or
Denon AVR 1612 (199$) with Pioneer's SP-PK21BS
All i want is decent enough surround sound and bass !!
Which is better ?? home theatre in a box or buying separately ?
Suggest some speakers.. & receivers
Edited by Ashik - 11/21/12 at 1:47pm
post #2 of 22
And one more thing...
Don't want over noise from subs.. want clear crisp sound from speakers !
post #3 of 22
Please !! someone help !!
post #4 of 22
What you want with your budget is going to be difficult. The size of your room is going to make a difference for your set up. If your room is large you will need better speakers. If you've got a small room then smaller less expensive speakers might do well. I would suggest for you to look at the new Pioneer Phase 2 speakers if you want a decent budget 5.1 surround sound.
Lets see: Denon 1612 $200
Front L/R : Pioneer FS52's $200
Center: Pioneer CS22 $100
Surround: BS22 $100
Sub: BIC F12 $200
For a total of: $800 dollars. This does not include shipping or taxes.
Or
www.newegg.com is have a sale on some Polk Audio speakers.
Denon 1612 $200
Front L/R: Polk Audio Monitor 60 $200
Center: Polk Audio CS1 $60.00
Surround: Polk Audio Monitor 30 $80.00
Sub: BIC F12 $200
For a total of: $740.00. This does not include shipping or taxes.
OR IF YOU'VE GOT A SMALL ROOM
Denon 1612 $200
Energy Take 5 $150 (5.0 set up)
Sub: BIC F12 $200
For a total of $550. This does not include shipping or taxes.
or
Denon 1612 $200
Definitive Technology ProCinema 60 5.1 set up $200.00
For a total of $400. This does not include shipping or taxes.
Edited by GusGus748s - 11/22/12 at 1:08am
post #5 of 22
Ok.. i'm thinking about only buying 3 speakers & sub... @ same budget
will add rear later..
suggestions please !!
post #6 of 22
post #7 of 22
By looking at your picture, I would suggest a better bed biggrin.gif. Also the room looks small, and buying bulky speakers will most likely hinder you. I would suggest going with satellite speakers and a 8" sub.
post #8 of 22
Suggest some satellite speakers for my room size then..
post #9 of 22
fwiw, the denon avr1612 is a solid choice. if you want great clear sound in your budget a pair of kef iq10's $250 on friday (iwould purchace asap as i would imagine these will sell out fast) at kef direct. and a klipsch rw-12d sub $300 at newegg this will give you a great 2.1 system for your size room.
post #10 of 22
That is a small room - look at the Acoustic Energy system from AC4L
Once you add it to the cart - the price will come in under $500
http://www.accessories4less.com/make-a-store/item/ACENAEGOPACK/ACOUSTIC-ENERGY-AEGO-AE12-5.1-Home-Theater-Speaker-Package-Gloss-Black/1.html
http://www.accessories4less.com/index.php?page=brand&id=ACOUSTIC+ENERGY
Edited by zieglj01 - 11/22/12 at 9:03am
post #11 of 22
I already did. Look at my last two suggestions. Or the last two posts.
post #12 of 22
What's the difference btw AVR 1612 & AVR 1613... other than airplay..network etc.. any notable difference in sound quality ??
found that amazon has 250$ for 1613.. 5.1
post #13 of 22
They will so-call sound the same.
post #14 of 22
Please suggest a decent home theatre receiver.. lost interest in denon AVR 1612 & 1613...
Requirments.. ::
Don't want many features.. like airplay... network.. etc.. not at all necessary for my use....
1st priority is audio perfomance !!
should be 3d supported !
post #15 of 22
Requirments.. ::
Overall the soud quality comes from the speakers, not the receiver. >
Denon does a good job with efficient power handling in surround mode.
Yamaha from the 6XX series on up, are nice.
post #16 of 22
Thinking about these to buy.. need your opinion...!!
Polk Audio Monitor60 Series II Floorstanding (Both front and back)
Polk Audio CS2 Series II Center Channel Speaker
Polk Audio PSW505 (SUB)
post #17 of 22
Howz pioneer receivers.. ??
post #18 of 22
BIC F12 is a better sub.
post #19 of 22
Thanks !!
Between,no one has used Polk Audio Monitor60 Series II Floorstanding @ back.. is that because wires are short rolleyes.gif
post #20 of 22
Thanks !!
What?
post #21 of 22
What?
Everyone is opting for different set of rear speakers... ??
post #22 of 22
You do not need a lot of speaker or sub to fill that room - How far are you going
to be back, from the placement of the speakers? Also, where do you plan to put
the surrounds?
  Back to Forum: Speakers
