Hello,
I am planning to buy my first 5.1 HT system this coming week so I would like to seek advice from you guys before ordering. The HT will be setup in my apartment hall (size 25 x 15 feet) and will be mostly used for TV, audio CDs and FM radio. I would also like to keep the budget below $1000.
I have zeroed in on below configuration -
Speakers -
L/R : Polk Monitor 40 for $109 (20-125w / 47Hz-25kHz / 8ohm / 89db) http://www.newegg.com/Product/Product.aspx?Item=N82E16882290202
Center: Polk Monitor CS2 for $149 (20-175w / 50Hz-25kHz / 8ohm / 90db) http://www.newegg.com/Product/Product.aspx?Item=N82E16882290212
Sub: Polk Audio PSW505 12-Inch Powered Subwoofer for $250 (23Hz - 160Hz ) or BIC America F12 12-Inch for $ 200 (25Hz - 200Hz)
Surround: TBD
Receiver -
Denon - 600W 5.1-Ch. Model: AVR1613 for $300
I am proceeding in the correct path ? Should I change any of my above configuration? I also need your advice on finalizing the sub and selecting the surrounds.
Thanks for your help !!!
Edited by Ivargat - 11/21/12 at 4:26pm
Speakers -
Surround: TBD
Receiver -
