I built my 120" Elite Sable screen tonight (which looks freaking awesome BTW) and I'm at the part where I mount it on the wall.
However I'm a tad confused because the instructions are kind of vague about everything.
It says to mount the bracket to studs, however, the bracket looks like this:
It's the bottom bracket there.
Now the problem is, it has 2 long holes on it and you are supposed to mount 2 screws to each mount. However, both screws will not fit onto 1 stud. So I'm confused by that.
Additionally it came with 4 of those plastic things you can hammer into dry wall, and then screw a screw into. Is that okay to use without a stud for this screen?
And it also says "drill a pilot hole for the size screw you have" but the problem is I don't know exactly what screw I have, since they didn't tell me in the package.
Any advice? Would like to hopefully get this up tonight!
