AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Plasma Flat Panel Great Found Deals! › Can Canadians buy warranty from squaretrade or do you have to go through costco ST?
post #1 of 4
Hi all,
I''m getting mixed feedback regarding squaretrade warranty. Looking through the forums, it looks like you can buy extended warranty from ST, but when i emailed and even called them, ST warranty is not available to Canadians?
Also, when i called ST, they said their warranty runs in parallel to the manufacture warranty. Ex: You bought a tv with 1yr manufacturer warranty and buy ST warranty for 3 years, you don't get a total for 4 years coverage, just 3.
If that's the case, can I purchase the ST warranty from Costco (i am a member) even if I didn't buy the tv from them?
I'm so confused!
PS: BB and FS warranty is easily double that of ST
Thank you guys!
post #2 of 4
Depends where in Canada you are living. I'm in BC and sad to say that square trade warranty is not offered here! I had to purchase my warranty through the store I bought from.
post #3 of 4
thanks, man. here in Ontario if you buy a tv from costco, you can purchase the ST warranty.
post #4 of 4
If u live in ontario you can buy the SquareTrade warrantee from costco but you don't Have to buy the TV from them.I called ST & as long as u live in the provinces covered u'll have no problem, but as some1 else said>>> u ONLY get 4 yrs. not 5, or maybe 3, i forget, but for 100$ that way better then 370$ @ bestbuy.
