AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Vizio E701i-A3 Owners Thread
Vizio E701i-A3 Owners Thread - Page 47
post #1381 of 2199
If there a way to break the WIFI connection on this TV. I am no longer using the internet features and for now want to avoid upgrading the firmware until the issues that have been reported in this thread are resolved.
post #1382 of 2199
One user reported having to factory reset, the rest of us had to turn off Adaptive Lumina. Doesn't seem to me there's major issues for those that are reporting in here.
Edited by NachoB - 7/2/13 at 11:38am
post #1383 of 2199
Pink slips
post #1384 of 2199
Im wondering if somehow my router is blocking necessary information that allows my tv to get updates.
All my updates have come from replacing the tv.
post #1385 of 2199
It'll come. Mine just got the update about 2 days ago.
post #1386 of 2199
Okay thanks
post #1387 of 2199
Went from 1.1.5 to 2.021 this evening. I went out around 8PM and by midnight the update had been installed.
SN is 04LFTRNXAP06589
post #1388 of 2199
Mine went from 1.1.5 to 2.0.21 some time over night. Backlight Control was changed from OFF to DCR and the Ambient Light Sensor was changed from OFF to MEDIUM. No other settings appear to have been changed (I had taken pictures after my TV was calibrated).
SN 01LFTRNXAP00331
post #1389 of 2199
Same here. Nothing else changed and i didnt heed to hard reset. Pic looksca little better
post #1390 of 2199
Regarding PIP working . I have heard that PIP was working on this set (not supposed) to. I believe NachoB and JJthenovice among others had experienced this. Does it still working after the software update. I am going to purchase one just for this feature and I can't find any other unit that has this feature
post #1391 of 2199
Okay, looks like my previous post was deleted. ?? Hmm, anyhow....
I owned the Vizio for about a month. Had problems with the wireless, problems streaming, problems with the apps, problems with lip sync, problems with freezing up and random shut-downs, really bad flashlighting around the edges. But the picture was amazing.
The wife talked me into returning it and getting the Sony for $600 more. Glad (so far) that we did as there have been zero issues (so far) with the Sony.
See if this post gets deleted. I won't continue to post on this thread knocking the Vizio, but I did consider my experience a valid point for those that are having problems with their Vizios just as I did. I'll only post now as answers for any requests to elaborate. Otherwise, see ya on the Sony thread wink.gif
post #1392 of 2199
The Sony R550(3D)/R520(2D) has PIP & PAP smile.gif
post #1393 of 2199
My set just updated to latest firmware and the PIP still works.
Edited by jjthenovice - 7/5/13 at 6:55pm
post #1394 of 2199
Hmm... mine just updated to 2.0.21 and now it's telling me my wired ethernet is disconnected and only allowing me to choose a wifi source. I've been using this set wired since I bought it, and this morning it's broken with the new update.
post #1395 of 2199
Anyone find a fix for the awful firmware update? My tv updated last night. Every time I turn it on, the set up screen shows, and I lose some settings. I no longer have to redo my internet connection (had to do a hard reset), but i still have to turn the backlight control and ambient light sensor back off every time I turn the tv on... I can't believe Vizio hasn't fixed this yet! Between this, and the horrible Amazon App, I'm thinking of returning this TV. mad.gif
post #1396 of 2199
I've just received the update and so far have experienced none of the problems other users have faced. I would suggest that those of you who are having problems try the following: Turn TV off and unplug it. While TV is off, press and hold power button (located on left side of TV) for at least 30 secs. If this does not fix problem try a factory reset (taking down all your settings before doing the factory reset). YMMV Hope this helps.
post #1397 of 2199
I had to go through the short set up again but no other problems after the latest update, the TV turns on FAST now.
post #1398 of 2199
Those of you having the issues after the update, I think I figured out the problem... You have to go through the WHOLE setup process and registration at the beginning. I'm not a very patient person, so I was going straight to the exit, since I don't use the tuner, and I'm not a fan of having to register the tv until I'm sure I'm going to keep it:rolleyes: .
post #1399 of 2199
2.0.19 to 2.0.21 last night. No settings were changed, and havent experirnced any issues
post #1400 of 2199
Mine also updated. Went through the brief set up process. No problems. Does seem like it turns on faster.
post #1401 of 2199
Anyone check their set with a calibration disc after the update?
post #1402 of 2199
The blacks seem blacker than before, but maybe it's just placebo affect.
post #1403 of 2199
I may recheck settings with the WOW disc later today.
post #1404 of 2199
I tweaked my settings today to reflect tge info from the hd709 disc. More specifically the contrast. Reducing contrast allows you to see extended information if available. The guys on the show felt if it is there, then they want to see it. I adjusted the contrast so it faded to background on 252 iirc.
I then had to slightly adjust color/tint
I then popped in my WOW disk. For comparison. If I use the wow disc to set contrast I end up with a setting of 80, if I use the 709 disc I get a value of 72.
The value of 72 gives me a nice gamma value on the wow disc of about 2.2. A contrast value of 80 gives me a gamma of 1.8
post #1405 of 2199
Four days after the 2.0.21 update and no problems at all. Picture still looks great. I think the folks who are reporting faster start ups are correct, I'm pretty sure I'm seeing the same thing.
post #1406 of 2199
Originally Posted by bigmoe View Post
So I'm watching Star Trek (original series ) on Netflix. Yes I'm an old Trekkie . Started watching "The Menagerie "and all the skin tones were a deep blue. At first I thought it was something with the hd episodes but I paused the screen and restarted and all went back to normal. Had my tv for 5-6 months and never saw this. Question, do you think it was with the netflix streaming issue that corrected itself when I restarted or is it something with the tv itself? All seems good so far as it just happened? Hope it's not something with the tv. I love it. Fingers crossed
bigmoe. how odd i had *exactly* the same problem right down to it being with original star trek season 1. i thought it was just something about the episode, but when my girlfriend went to watch something else it was also blue. i went into settings and they all looked good [i.e. the way i set them], so in frustration i clicked from one mode to the other [e.g. from movie to standard] and bam it started working again.
i also got the new 2.x firmware at some point recently, but i can't remember whether it was before or after this issue.
post #1407 of 2199
Work 70" finally got the update about a week after my personal 60". Today I turn it on, made a loud "pop" so I turned it off. As it was turning off, it popped again. I turned it back on, and couldn't find Skype in the store. I did a factory reset and no more popping, and Skype was right on my dock. All good now.
post #1408 of 2199
amazon app used to fail the first time I tried to run it, and work the second time. I'm still stuck with wireless only even though i have a cat6 cable plugged directly into my gig-e router... total shame. Now the amazon app won't launch at all. I love this TV and you couldn't beat it with a stick, but this new firmware update has me aggravated.
post #1409 of 2199
Check your DHCP settings in the network settings on the tv. After the update, mine defaulted to "off". You will either have to turn it back on, or manually assign an IP adress for the TV.
post #1410 of 2199
Got my replacement 701 today, it was born 3 weeks ago according to S/N. Seems good at 1st glance. It came with V2.0.19 firmware. Saw a couple Very minor flashlight effects on bottom edge when all white screen, barely noticeable. My 1st set had much more. No bright pixels. I'm happy so far, we'll se how this one does.
