How is the picture affected if you adjust the color offset s in the same direction by the same amount? Say from 128 to 100. If the color relationship status the same, then does it adjust brightness of the color? could you potentially tweak black level by reducing the rgb offset? Ive only adjusted them by a few points to reduce a slightly green overtone, but the adjustment range is very large.
post #541 of 1319
1/29/13 at 9:15pm
![Wow: World of Wonder [Blu-ray]](http://cdn.avsforum.com/1/11/50x50px-ZC-1166fb14_B00462PTDQ-51E0ByQYHsL.jpeg)
.. Do you know where Jimmy Hoffa is buried?
Like you mentioned, I only like the effect for games, not BluRays or HD Cable.
