AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › INFOCUS X10 blue tint
post #1 of 2
I have an Infocus X10 with about 2500 hours on the original bulb. Today the picture showed a blue tint after the projector was on for about an hour. You could see the image, but the picture had a blue tint to it. The tint is uniform across the picture.
I shut it down for about 10 minutes, turned it back on, the picture was normal for a few minutes and then the blue tint appeared again.
Does anyone know if this means that the bulb is going or is it something else. I want to order a new bulb but don't want to spend the cash if it is another problem.
Thanks in advance.
post #2 of 2
Definitely not the bulb. Likely a problem with the projector. If you have brilliant color turned on, might try turning it off. I've seen some odd things happen with it on, although not what you describe.
