AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Did you measure your sub with measurement gear ??????
Poll Results: Did you use measurement gear to setup your subwoofer
  • 80% (40)
    Yes
  • 20% (10)
    No
50 Total Votes
post #1 of 81
It seems to me that there isnt as much talk of measurements and measurement gear in the subwoofer section. Just wondering..... KG
PS: even if you ran a test tone with a handheld meter is a Yes, but you can explain if need be....
KG
post #2 of 81
We're running two subs. I used a Radio Shack digital sound meter (33-2055) and tape measure to set the sub gain (volume) at 1m (thirty-nine inches), 63/64 dB with sound meter settings of C/Slow settings.
After balancing each sub, one turned on at a time and after running Audyssey, XT room correction analyzer, at listening position, I set the pink noise to 69dB. Either today or Monday, depending on who's open and isn't open, I'll be ordering up an Anti-Mode 8033S II.
(Anti-Mode 8033S II ordered and delivery expected on Wednesday.)
Warning to all, I found out the Anti-Mode 8033 has been upgraded and a few changes have taken place folks should be aware of. If one has been reading old information, they won't know about these changes that are currently in the pipeline.
http://www.dspeaker.com/en/products/anti-mode-8033.shtml
Scroll to the bottom of the sheet to see the differences, new vs old. The old is the 8033C and the 8033S. The new is the 8033Cinema and the 8033S II. The main point to note is, the 8033Cinema has been dumbed down to one output so if this is the model purchased, you'll need to Y-split the output signal as oppose to the dual output, 0/180 phase of the old version. In the case of the 8033S II, it has been smartened up and now has 32 filters as opposed to 24 filters, in my opinion, that's a huge analyzing upgrade. Just a heads up on these points.
Hope the above helps.
Edited by BeeMan458 - 11/23/12 at 9:51am
post #3 of 81
Dual subs measured with mains together.  Used Omnimic for measurement, 1/12 octave smoothing.  REW used to import the file and capture screen shot.
post #4 of 81
That graph meets the definition of "Sweet."
post #5 of 81
Yes, of course and it makes a huge difference in sound quality once you tame your response. You might not like the lower spl's from a flat curve though(if one had a peak). I need to show my new graph, same +/- 2.5 dBs smooth but from 5-100hz.
post #6 of 81
Just put my order in for the new Anti-mode, 8033S II with more filters. Should be here Wednesday. biggrin.gif
(Scroll to the bottom of the page for version comparison information.)
My understanding of how this setup is to be dialed in is, use the balanced sub settings, run the Anti-Mode and then run Audyssey XT.
post #7 of 81
post #8 of 81
I run Audyssey last too. I ran it first before i tweaked with my MiniDSP and lets say i was not happy with how it fattened the response. Raising a null is impossible, but i am told Audyssey can do it with out a problem, sounds like bending pysics, and my distortion checks told me the same....you cant bend it
post #9 of 81
I make Archaea do all my measurements :P
I've used REW, but with the Audyssey mic so take that for whats it worth :P
post #10 of 81
Not a clue as I've read you can flatten peaks but you're on your own with nulls.
post #11 of 81
One of these days I'll get an omnimic and I will, but it hasn't happened yet frown.gif
post #12 of 81
Dual JL F113's measured together with mains using an OmniMic. 1/12th octave smoothing. The system is using Audyssey XT32 but is from before I ran Pro which improved things again.
post #13 of 81
It's either that or you have to buy a Bass Boat. tongue.gif Just think along the lines of the next new toy should be an Omnimic and it will happen. Gotta have new toys when one can. If you think of it as a measuring device, it may never happen but if the money is there and you see it in the light of entertainment, then it makes perfect rational sense.
post #14 of 81
Sub only raw in room response 120hz crossover 1/12th smoothing no E.Q. of any kind used. Did this while testing two different amps on my passive unit. I am currently in the "research" process for an external E.Q. device.
post #15 of 81
It has to be the easiest device to use and interpret. You will love it !!!
Edited by kgveteran - 11/23/12 at 10:19am
post #16 of 81
That is awesome for new EQ.  Looks like you could take down the 50hz region about 5db and be set!
post #17 of 81
The happening deal for an external EQ device is the Anti-Mode 8033S II. I ordered one today.
post #18 of 81
post #19 of 81
I currently use a MiniDSP to EQ. For $175.00 i can say its a steal !!!!!
post #20 of 81
I check for peaks and nulls with my old RS SPL meter and REW software. After setting up the best position for my subs, I just run Audyssey.
post #21 of 81
Thanks! Same thing I was thinking then perhaps a little "house curve" for the lower octaves to compensate for my older ears. biggrin.gif
That is one option I was considering, looking fwd to your impressions and maybe some before and after measurements.
post #22 of 81
Sadly, I don't have an OmniMic yet and other than Audyssey, MultEQ XT, I've nothing to compare it to. When I get the Anti-Mode with it's thirty-two filter capability dialed in, I'm happy to give my before and after impressions. What other EQ's can one insert into their system to both analyze and EQ the response curve?
Edited by BeeMan458 - 11/24/12 at 11:59pm
post #23 of 81
Sadly, I don't have an OmniMic yet and other than Audyssey, MultEQ XT, I've nothing to compare it to. When I get the Anti-Modem with it's thirty-two filter capability dialed in, I'm happy to give my before and after impressions. What other EQ's can one insert into their system to both analyze and EQ the response curve?
Since you are getting the Anti-Mode I would suggest using REW software available for free here to see exactly what your system is doing with each and every setting. http://www.hometheatershack.com/roomeq/wizardhelpv5/help_en-GB/html/index.html All you need is a laptop with an external sound card and a spl meter. Lots of folks here use this to measure and tweak their systems for optimal performance.
post #24 of 81
I liked the idea of the plug-n-play nature of "OmniMic" vs the learning curve of REW. I'm old, my brain is worn out........whine..........tongue.gif
You're right, it's an option worth consideration.
I've downloaded REW to the desktop, it's nighttime, I'll start the learning curve in the morning. tongue.gif
Edited by BeeMan458 - 11/25/12 at 7:18am
post #25 of 81
When you guys get used to using REW and setup it is just as easy as setting up a mic and running the sweep. With Omnimic I had to pull out the laptop and setup up the mic too. THE initial setup of REW is much harder than Omnimic but again, once setup it is a breeze. I just ran some THD numbers on my subs and I have more headroom that I thought. I am pretty excited.
post #26 of 81
Out of curiosity, can I use the mic that came with Audyssey, MultEQ XT or do I need a microphone like the one that comes with OmniMic?
(It's morning, I'm drinking coffee, I haven't opened REW yet.)
post #27 of 81
I think you can use it, I am not sure how accurate it is below 20hz but if you have a RS meter that is as simple as it gets, just don't use the correction files. I use a Spectrum labs calibrated Behringer mic. It is like the omnimic.
post #28 of 81
The benefits of the Omnimic are that it includes everything needed, other than a computer, and ease of use. I've used REW with a Dayton mic and the quality of my internal sound card's mic input (an add on card, not the motherboard sound circuitry) limited its usefulness. I would have had to buy yet another sound card/external sound device in order for REW to be of much use and it was easier to get an all-in-one solution than to do that. The ease of use of the Omnimic is phenomenal and I am not a novice.
post #29 of 81
I have next to me a Radio Shack, digital sound meter.
Agreeing, regarding omni-microphones, getting "OmniMic" seems the better way to go as Parts-Express supplies a calibrated Dayton Audio OmniMic (download unique calibration file and it's good to 5Hz) with user friendly software for $300.00.
At this time and point, REW isn't looking good.
"Need more coffee Scottie."
Over at Parts-Express, I just put in an order for a "Dayton Audio EMM-6 Electret Measurement Microphone." It should be here in about a week.
(Great, the microphone needs a phantom power supply and a cable. It's Sunday and I can't cancel the order.)
Bit the bullet, went to Amazon and picked up a phantom power supply with USB and XLR cables included.
http://www.amazon.com/gp/product/B0073KC9TA/ref=oh_details_o00_s00_i00
(It was a better deal then the one at Parts-Express in that the deal includes two 25' XLR, microphone cables and a USB cable.)
Next time I stick to drinking morning coffee and reading about what could be. tongue.gif
Edited by BeeMan458 - 11/25/12 at 10:54am
post #30 of 81
Any updates?
Travis
