AVS › AVS Forum › Video Components › Home Theater Computers › Breaking up FlexRaid array? Anything need to do to remove a HDD from a FLEXRAID server ?
Breaking up FlexRaid array? Anything need to do to remove a HDD from a FLEXRAID server ? - Page 2
post #31 of 38
^ reason for that post is everything I am seeing is leading me to believe it's a bad drive that is giving me the problem. Not 100% dead yet but some issue on it. It's one of the GREEN drives. I might keep trying adding one more at a time each night and seeing if it takes till I find the bad one.
post #32 of 38
This issue is not one with your drive. I have had this issue before as well.
post #33 of 38
Btw no issues with green drives for almost a year in my flexraid server.
post #34 of 38
Any idea what it is ?
I just make a 12TB pool with 4 3TB drives (one totally full) it took 6 hours but it works fine.
I plan to try to make another pool with the others and figure out which drive is giving me the error. Then I will just copy the data from it and exclude it from the pool. I don't mind RMA it and add it back in the replacement later. I have enough storage to do this.
One of them is clicking. It's either an EARZ or EARS 2TB. I don't want to take a chance. Once the flexraid and snapshot is up and running I don't mind as much a failure.
post #35 of 38
I hate to be so critical because I used to be a WD guy. But I have had luck that is terrible recently. I forgave the first few RMA I did... but this is just silly now.
post #36 of 38
How did you fix ?
post #37 of 38
FWIW, I've had good luck migrating all data off the disk, then "remounting" if that's the correct verb.
matter of fact, had to do it too a WD blue 1T last weekend.
post #38 of 38
Your saying you basically copied off the data from the original to the new flexraid array- then reformatted and remounted the drive raw ????
