AVS › AVS Forum › Video Components › Home Theater Computers › FREE windows 8 bluray solution for HTPC
FREE windows 8 bluray solution for HTPC - Page 2
post #31 of 33
Has anyone tried DVDFAB Media Player
post #32 of 33
It works to some extent, but its very buggy and although some menus work, a lot either lock up or don't work at all.
It is based on XBMC 12 (It used there source code)
In its current state I would not recommend it.
post #33 of 33
Originally Posted by elaine98 View Post
This article will guide you to download and place the AACS and BD+ DRM libraries and keys in order to play Blu Ray on Windows 8 with VLC for Free.
Step 2: Download the Blu-ray playback addon pack from: here, and install the Key file from addon pack – “KEYDB.cfg”
Wow! This actually works! It works on Windows 7 also with the latest VLC, but you have to put the KEYDB,cfg in \AppData\Roaming.
Edited by blazerqb11 - 12/7/13 at 3:59pm
