I finished my last build yesterday, and I've got a lot of parts ready to go for my next build, so lets get started...
I am building a single center-channel speaker to go in my fireplace. The fireplace opening is 32.5" wide x 27" tall. It is 19" deep at the top, and 23" deep at the bottom. The sides close in toward the back, too. I never burn anything in it, so I don't mind putting a speaker in there. I don't want any ports blowing soot around, though, so I need to go sealed or front-ported. The fireplace is visible in this picture:
I have a fiberglass SEOS-15 waveguide and DNA-360 compression driver, and an AE TD15M-8 midwoofer. I will be building speakers with the same drivers for the left and right next, and I always use subs (a THT currently), so I only need to be able to blend around 80Hz, but I view some additional extension as a plus. I want to go passive later, but Bwaslo has shared MiniDSP settings with me for the drivers that I'm using to get started. Thanks bwaslo!
So, I am open to suggestions for the cabinet design, if anyone has been thinking about these drivers and what they would do with them. I saw LTD02's chart here with some cabinet volumes and port tuning: http://www.avsforum.com/t/1291022/hey-guys-we-need-a-little-rallying-here/4350#post_22160832
Judging by the looks of Erich's CNC front baffle for the SEOS-15/JBL, which is 17.25x25", I can make my drivers fit in the vertical space, and maybe even have room for a slot port. The AE woofer does have a slightly larger OD at 15.563" vs. 15.25" for the recess diameter in Erich's JBL baffle, but that isn't a huge difference.
All my builds thus far have been from plans, so I'm having to learn a bit more this time, and I've got more questions. Such as:
1. With the Econowaves that use the (tall) QSC 152i waveguide, I read that it was important to minimize the center-to-center distance between the waveguide and midwoofer. So I know that the c-c distance is important for tuning. But that maybe it need not be minimized as aggressively with the shorter SEOS waveguides (as compared to the 152i). And I will need to have my waveguide and midwoofer pretty close just to fit in the available space, but is there an "ideal" distance between the two? Do I need to use the same distance that bwaslo used, so that I can use his minidsp settings?
2. I would like to mount my waveguide and midwoofer in recesses so that the they are flush-mounted in the baffle. But I remember that it was important to mount the midwoofer on the back of the baffle for my Econowaves to line up the acoustic centers of the drivers. Maybe this doesn't matter for active speakers, but I want to go passive later. Are there any acoustic issues that I need to be aware of as it relates to flush-mounting my waveguide and midwoofer?
3. The center of the waveguide will be about ~21" off the ground, and my ear is ~39" off the ground in my listening position. My listening positing is 13' away from the front of the fireplace. Are there any acoustic issues with sitting that far above the center of the waveguide? Should I consider angling the speaker (or the baffle) up to point it at my ears?
4. If I decide to go ported, I will probably need to make the baffle wider to achieve the necessary volume. I've been playing around with the dimensions and calculating volume in this spreadsheet. Are there acoustic reasons to avoid a wide baffle? On the other end of the spectrum, should I consider making the baffle take up the full area of the fireplace opening, so that it will be flush with the tile surface and thus effectively 59.5" wide (the full-height fireplace column is that width, with no mantle, and it sticks out 22.75" from the wall).
I know that I am asking a lot. Any feedback is welcome.
-Max
-Max
I made the speaker too tall to fit in the fireplace. I didn't measure the fireplace opening correctly.
