AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Would a dedicated video card with hdmi output actually send sound out
post #1 of 5
Hi,
I am playing with different options to get better sound out of my HTPC
Everything is onbard an hdmi equipped Asus m/b, I am generally satisfied by the video output but the soundis a big no-no; horrible static through hdmi (a major flaw of this board)
For now, I have installed a dedicated sound card (I had laying around) with optical audio out to my receiver, its ok but only a temporary solution as far as i'm concerned
I could replace the m/b altogether with another hdmi equipped without any reported issues, but while looking for computer components deals, I might have came across a simpler solution
If I install a dedicated video card with hdmi connection, I might get decent sound of it, as opposed to sound from my flawed m/b
So my question is: If I just pop-in this hdmi fitted video card in there, should I get any sound out of it "automatically"?
I mean, is the videocard pci-e connection to m/b sufficient to grab the audio from the computer, or do I need some sort of additionnal connection to do that?
Hopefully my question makes sense to you
post #2 of 5
Yes, a modern video card has audio on the HDMI output. You do have to choose the video cards audio output in "Play back devices" in Windows 7.
post #3 of 5
OK, then, the next question is:
could those horrible statics I was getting with the m/b's hdmi ouput come out just the same out of the separate video card as well?
Do I need to try it to know for sure; it would suck to buy & install it & endup back at square one, as the store should replace an opened packaged "doa" but I doubt they would refund
For now, I have optical out from a SB X-Fi & sound output is clean
post #4 of 5
I've never gotten any static or noise from the HDMI output of the various AMD video cards I've had. I currently have an Asus motherboard. My advice is to get a AMD HD7xxx series card.
post #5 of 5
All is well, sound coming through hdmi, I coudn't get a hd7xxx as it required pci x 3.0, and my lowly board only supports 2.0
Still very happy to have this working the way I want to, so thanks for your help
