AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › How to Control Two Separate But Identical Components With RF Remote?
post #1 of 4
I am building a new house and plan on having 2 home theater rooms, one on the first floor and one in the basement. On both floors, the components will be located in a closet on that floor (2 separate closets). What I would like to know is if I can have the same brand and model receiver for each room controlled by separate Logitech Harmony 900 RF remotes without one interfering with the other. In other words, when I push a button on the remote on the first floor, is it also going to send the signal to the receiver in the basement? Thanks in advance for the help.
post #2 of 4
Very unlikely. Set one up with R.F. and the other with I.R.
post #3 of 4
I would recommend using a RF remote that communicates with a base station/processor that allows for IR routing. Pro Control and URC have products near the Harmony price range that absolutely blow it away in terms of functionality.
post #4 of 4
It is my understanding that the Logitech Harmony 900 communicates with a base station and then sends the commands via IR. Is there a specific model of Pro Control or URC you recommend that would work for this scenario?
  Back to Forum: Home A/V Distribution
