AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Please help me decide between "Pro8200, Acer H6500"! Thanks!
post #1 of 3
Hi, I'm having trouble deciding which projector to buy. Pro8200 is my first choice, but it's 800$, but AcerH6500 is 650$, and I mainly use it for gaming, but I'm not sure which one has lower input lag? Thank you!
post #2 of 3
you missed the newegg 650 price for the pro8200 by 2 days.
I don't know which would be good for you, maybe look at both forum rooms and read the amazon reviews.
I know the pro8200 is good for gaming, I'm just not sure about the acer h6500. Check warranty, bulb life, bulb replacement costs, look at inputs/outputs of both devices. Look at the last 4 months of posts on both, and give it your best shot. Look to see if people are reporting problems, how is costumer care, how is the Rainbow Effect on both. Etc.
There are supporters of both PJ's, so after you read all the reviews/forum room stuff, come back here and tell us what your thoughts are, and we might be able to help narrow it down for you.
I mean , do you CARE if one PJ is only one year warranty and the other has 3 years. You might not the first year, but in year 2 and 3 , you might. smile.gif
I don't think the acer has any internal speakers, the pro8200 has 2 speakers 20 watts 10x2. You can check the features and compare them. On this site, the pro8200 is rated as number 1 under 1,000.
post #3 of 3
I know! I was really disapponted when I found out it's not 699 and more, don't know when it will be on sale again, I can;t find too much reviews on H6500, all I know is 1 year warranty, 3500 Hours bulb life, and someone said the lag is about 13ms. I really like pro8200, it's just I missed the deal, so I'm not sure there will be another one coming. Thanks for your help!
