AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Is my HDTV dying?
Is my HDTV dying?
post #1 of 8
I have a 47" Philips that is approaching 3 years old. It has gotten significant use over these years.
I've always though my picture looked rather well on my blu rays and HD cable content.
Just out of curiosity I decided to run a "INHD" video calibration setup and see how it went.
To my interest after setting the brightness to the point of seeing the 4th shaded circle I proceeded to the contrast setup
The contrast setup consists of 11 different shaded rings ranging from light to dark. The test recommends to set contrast to the point of where the 11th ring becomes visible.
Even at 100% contrast the 10th ring is barely visible and the 11th ring is non existent.
Is it advisable to run contrast at 100% or should I just lower contrast and increase brightness?
Thanks for any help guys!
post #2 of 8
damn, no opinion on this guys?
post #3 of 8
Perhaps if you waited more than 2 and a half hours, people would respond.
post #4 of 8
Lol. Yeah I'm a little tipsy right now and got kinda antsy.
post #5 of 8
It's also possible that your set just doesn't have the best "gray" scale to calibrate to. Some sets have a better gray scale than others and one with a lesser gray scale would give what you describe with the contrast setup. I'd just chalk it up to your particular sets design.
post #6 of 8
Where is the Brightness (Black Level) setting? Reduce that. And then start again.
Please be advised that some manufactuerer's Advanced Settings stuff takes control of the Backlight Level, disregarding where you set it. Like Dynamic Contrast Ratio as one example.
Backlight Level
Brightness Level (Black Level)
Contrast Level (White Level)
The Brightness Level and Contrast Level has no effect on longevity and does not hurt the set. The Backlight Level, generally you hope that you dont have that full blast, so as to save life on the lamps. Over the life of the unit, (were talking decades) you will have to keep turning up the Backlight Level to keep a constant lumen output as the bulb wears itself out.
post #7 of 8
My LCD set does not have a Backlight level that I have noticed. The brightness setting is at about 50% right now.
Active control is turned off.
Dynamic Contrast is turned off.
Color temperature is set to normal.
post #8 of 8
No Backlight Level control?
Bummer.
