AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Polk PSW10 to Klipsch Sub-10
post #1 of 9
I am slowly upgrading my home theater system and I am looking to replace my old Polk PSW10 sub. Newegg appears to have a deal on a Klipsch Sub-10 and I'm wondering if this is a decent upgrade path. I currently have Polk Monitor 70s in the front, a Polk CS2 center, and Polk Monitor 30s in the rear. All of this will be driven by a Yamaha RX-V671 once it ships (it's replacing an Onkyo TX-SR505). Any help or advice would be appreciated.
post #2 of 9
What's the max you are willing to spend? We like to spend every last cent of your money.
post #3 of 9
I'm pretty much in a budget price range of around 250 or less.
post #4 of 9
You'd be better off going with a Polk PSW505. They can be had for $200 when on sale. Much better than the one you're considering. Keep an eye on amazon and
newegg as they go on sale fairly often.
post #5 of 9
I'll keep an eye out for them. The PSW10 just wasn't cutting it anymore. I was watching the expendables 2 last night and during all the scenes with explosions the sub was producing a lot of port noise/rattling noises. If I turn the sub down, you don't hear anything coming from it. After I replaced the front speakers (had monitor 50s before), the 70s seem to be out doing the sub. It's just time for a new one.
post #6 of 9
I use the same front three speakers as you for movies and the PSW505 will definately put out much more bass than the Monitor 70's.
post #7 of 9
The PSW505 has dropped back down to $199 at both Amazon and Newegg. It was $250 at both during the last week and Black Friday. I'm going to pull the trigger, thanks for the help!
post #8 of 9
Good for you. You'll notice a big difference over the PSW10 sub. It's a great deal for the price.
post #9 of 9
I just upgraded from the polk psw 10 to the Klipsch RW-12d ( reading this forum is a sure way to spend money darn it) even though the little polk performed better than you would think, the Klipsch is quite a bit better. I've just got to run Audyssey.
