My sub is a custom job built off a TC Sounds TC-9 Motor.
I was hoping Winisd would at least have some TC Sounds subs but it doesn't.
I was going to just build a completely cubed box with all sides the same dimensions but after playing around with WinISD I noticed the different dimensions it suggests for different setups.
I know there's no way to know what my ideal set-up would be so is it ok to just go with my original design?
Driver is a 33lb 15" being powered by 1400 watts.
I was planning on a 21" X 21" X 21" sealed enclosure yielding 4.2 cubic feet.
