I plan on getting a onkyo-tx-nr515 I just need suggestions for speakers. Ideally I would like to get higher quality on the fronts and center and cut back on the surrounds. I don't have a budget just yet, but I would like to keep it under 1k not including the sub. I will worry about that later. So I need some suggestions. The room is still be constructed so I am really not limited to much, the room is about 20' by 12'. Thanks
