:eek:I have a penny dmr ez28. I went to record a tv football game and the unit turned on then would not open. There was a disc in the unit not finalized. I wanted to put in a blank so I could record th whole game. The unie would not open. I unplugged it and when I pluged back in it went through the test and I was able to get the disc out. But now the display flashes the number 100107 then says no disc. I went through the trouble shoot in the manual and no success. What should I do? I love this unit.
Update unplugged the unit and let it set. Went through the trouble shoot. Now can play a recorded DVD. Tried to do a firmware update but no success, unit states cd not comparable. Still can not change channels frozen on 100-110 tried to do a reset pressed the little reset button and do a new setup but it won't.
Reset and channels won't reprogram, but the unit will play a disc. What now?
Edited by Ping123 - 12/8/12 at 5:50pm
) is very reputable and your best bet for fixing what you described. Your next best alternative would be to try and find a used EZ-28 on somewhere like Craigslist.org but then you don't always know how long a used recorder will last either(although more than likely it will last for a long time). Note Panasonic DVDRs aren't as easy to find as they used to be, for sure the HDD and EZ models. Probably the most painful thing about having Mick fix your DVDR would be the shipping to CT, somewhere between $20-30 I'd guess, one way. If you lived at all near CT that would be the handiest.
