AVS › AVS Forum › Video Components › Home Theater Computers › Watching all three tunners in HDHomeRun Prime at once?
Watching all three tunners in HDHomeRun Prime at once? - Page 2
post #31 of 33
And also does each xbox remote connect with it individually? Seems like one remote might interfere with the others. Or I guess it would be nice to have one remote in the home theater to control WMC on the computer and two other xbox 360's instead of having to fool with multiple remotes.
post #32 of 33
It will interfer if you use IR remotes. And your WMC PC remote will interfer with Xbox as well if Xbox is configured to accept media remote. Your only bet is to find out if there is any Xbox specific RF remote that you can associate to specific Xbox like the Xbox controllers are. Or you can just use the Xbox controllers.
post #33 of 33
Originally Posted by Dark_Slayer View Post
This would be miles easier . . .
Good to know, doesn't look like a hack just a feature built in to release Release 20091024 and later versions of QuickTV http://www.silicondust.com/support/hdhomerun/downloads/software-changelog/
Thank you for the very useful post. I'm running an HD Homerun Prime with the cablecard decrypting Mediacom cable in Georgia. Now I'm able to use QuickTV to view two or three different channels at the same time. Football season just became more fun. I've had no problem viewing any channel with QuickTV but I don't subscribe to premium channels like HBO, etc.
The HD Homerun Prime rocks.
