Hi all-
I am considering a TX-NR515. I am aware that the 2nd HDMI output does not upscale. I would use it for a 2nd TV in another room. My question is whether the 2nd HDMI passes through the audio when the audio signal is extracted for the Main HDMI (so that the receiver provides the audio in the main room). I want to be able to get audio from my TV in my 2nd room using the 2nd HDMI output (the "OUT SUB") while at the same time using the receiver in the main room for the main HDMI output. I understand I would be watching the same input source on both HDMI outputs. I have reviewed the manual and I can't tell if it will do this for the 2nd HDMI out unless I pass through the audio to the TV on the Main HDMI out.
