Okay...so I'm finally getting my theater going. I'm finishing it with the basement, and the theater is proving to be the stalling element of the project. I'm having a hard time making decisions and understanding the best way to do things, and it's slowing me down.
First things first...the room. The room is 17'3" deep and 15'7" wide. I have 9 foot ceilings. There are no windows in the room, but there is a double door on one side. Please see the following snapsnot of the layout on graph paper (I'm working on a nice google sketchup, but I don't have time to finish it right now).
I am planning to have a fairly simple stage at the front, a 10" riser in the rear, and two rows of seats. I am hoping I can get 5 seats in the back row and 4 seats in the front row, but I have plenty of time to figure that out. Right now I figure out the riser, and the hvac.
Looking at the room, the wall opposite the door is a concrete wall...the foundation of the house. The room to the right of the door (the top of the picture) borders a family room, and the wall labeled "screen wall" borders a guest bedroom. The wall with the door borders a hallway (obviously).
Okay...back to the HVAC. I live in Utah, and the temperature in the basement has an amazingly consistent temperature. Because of this, I'm going to just pull heat runs off the existing trunk line for the upstairs (we have a rambler) for all the rooms in the basement except the theater. The idea is that most the time, the vents in the basement will be closed because the temperature down there is so ideal year round. The only room I'm concerned about is the theater. I fear that it will get hot in the there with a bunch of people and a projector (all other equipment is rack mounted in the utility room). What are my best options for HVAC in this room? I'm going to build a soffitt/valence around the room to give the ceiling some depth, and I'm thinking I may be able to install a mini split system inside that valence. Does anyone have any thoughts or opinions on that? Will that sufficiently cool the room without any sort of return air? I fear the air in that room may get stale or stagnant. I'm also thinking of installing the projector in the valence, and if I do that I'll mount a whisper quiet fan with a vent to outside. Can anyone offer any suggestions on what I can do to heat/cool this room?
Second question...the riser. I'm going to make it 10 inches high, I am just uncertain on how deep to make it. I realize that 17'3" is somewhat short, and I'm hoping for a 110" screen. Can anyone give me any advice on deep to build this riser? I'll make it the entire width of the room...it's just the depth that's in question. I would like to get all reclining seats, if possible.
I'll get the wiring to the room finished up this week, and I'd like to get the riser built this weekend. I also need to get a handle on the HVAC so I can figure out which way to go there.
Thanks in advance.
Dan
Thanks in advance.
Dan
