AVS › AVS Forum › Audio › Speakers › TX-NR616 vs Onkyo HT-S9400THX
post #1 of 2
Hello!!! I have a few questions on my journey to upgrade my old HTIB system that I've had for almost 8 years to something new. I saw the HT-S9400THX. Thought this was a good system. After doing some reading I saw that the speakers that came in this system were consider weak at 86db.(This was in another thread on this forum.) Reading into some more threads I saw someone recommended the TX-NR616. Problem with this I don't know how to build a system piece by piece and what the best speaker for my budget would be. What would you guys suggest I do? Go with the HTIB or start building the system one piece at a time. My budget is around 700.00 The room that this is going in is 14x20 and it will be mostly used for 25% TV 50% Games 25% Movies. Thanks for the help!! smile.gif
Edited by KennyPa - 11/25/12 at 6:31pm
post #2 of 2
2 - Monitor 30 Bookshelf Speakers
2 - Monitor 50 Towers
1 - CS2 Center Channel
1 - PSW-10 Sub-Woofer
I found these speakers on CL. Would these make a good setup with the tax-nr616?
  Back to Forum: Speakers
