AVS › AVS Forum › Home Entertainment & Theater Builder › General Home Theater & Media/Game Rooms › Any electricians here: Florescent dimmer for incandescent lights?
post #1 of 7
I’ve acquired a commercial-grade Lightolier florescent light dimmer that I’d like to use in my home theater. Is there any problem using a dimmer like this for residential incandescent lighting?
Here’s a link to the manufacturer’s installation guide, if that helps.
http://www.philipslightingcontrols.com/assets/cms/uploads/files/sunset-momentum/85-6290A0.pdf
Wayne A. Pflughaupt
Incandescent
post #2 of 7
I'd have concerns about the load rating, e.g. how many incandescent watts you could safely control, with this 2-wire fluorescent analog dimmer.
I wouldn't think of doing it, as this is not what it was designed for, marketed for, nor approved for.
I don't know how well it would work either.
Note - I'm not an electrician, nor even experienced, but I do understand the phrase 'to code', and that would not be 'to code'.
post #3 of 7
Technical/Sales assistance: 1-800-526-2731
Call and ask.
post #4 of 7
I don't think that Lightolier will tell you it's OK to use that fluorescent dimmer, for an incandescent load - even if it's perfectly OK. That's not what it is 'listed' for. They would be liable.
post #5 of 7
Wow, you’re right – I totally forgot about the load! What a gaff! duh.gif An incandescent dimmer carries the full amperage of the load, which would not be the case with a fluorescent dimmer.
Wayne A. Pflughaupt
post #6 of 7
I didn't say it wouldn't work. What is the load rating, for an incandescent?
post #7 of 7
I’ll be running four recessed cans, total of 200 watts.
Wayne A. Pflughaupt
