AVS › AVS Forum › Display Devices › Display Calibration › Grayscale variances - different patterns, plasma calibration
Grayscale variances - different patterns, plasma calibration - Page 5
post #121 of 273
That's correct, I believe he was referring to the 2011 models and he may have been referring to the THX modes specifically. Here is his statement:
"Greetings
Peter,
The THX mode gamma is based on test patterns in the 6.5% size. The larger your test patterns, the lower the gamma number becomes.
I did a run with boxes in the 20% size range ... and got 2.07 range gamma. Then for fun, I went to a 10% window size and the gamma went to 2.16 range.
The test patterns you use matter. No sense killing yourself over this gamma number. It actually is where it is supposed to be.
regards"
post #122 of 273
Originally Posted by JimP View Post
Here are the patterns for those interested.
Here is one using PC levels 0 to 255 graduant.jpg 313k .jpg file
and one with Video levels 16 to 235 graduant.jpg 310k .jpg file
Next step for most of us is to figure out if the large or small window patterns (or something inbetween) works best.
Indeed.
Anyone know the process how to make a disk once we've figured out the correct pattern size?
post #123 of 273
Here's what I came up with for a 6.5% size pattern @ 50% brightness on a black background.
6.5% size @ 50% brightnessRGB126c.jpg 152k .jpg file
Edited by JimP - 12/12/12 at 9:09am
post #124 of 273
I used 127 in RGB for the 50%. Seems that I vaguely recall 50% should be 128. Can anyone confirm which is correct.
(219/2) + 16 = 125.5
Then it depends on which way you round. In CalMAN we round up to 126.
Edited by sotti - 12/11/12 at 9:18am
post #125 of 273
if you use Calman 5 just activate "Pattern Change Prompts" in the "Source Settings", click the read button and Calman shows You the RGB values. No need to calculate.
I just did so and rebuild the 75% color APL Large Pattern of the AVSHD709 BD in Photoshop just to verify whether my approach is right. Window sizes are exactly the same. Than created an mp4 file with Sony Vegas Pro using REC709 in the project settings. But after comparing the measurements of the original AVSHD pattern with my own, luminace, saturation and hue differs. Seems not to be that easy creating your own pattern disc. Any hint?
post #126 of 273
Hey,
I'm new to this great forum and just read this thread. As a DIY calibrator with about 1 year experience, and still learning, i'm always interested optimizing my VT50EU. Just wondering if someone figured out the correct pattern size for Panasonic VT30/VT50? Did some pattern from 2% to 20% (area) and 50% stimulus (RGB126/126/126) for testing. If anyone still interested:
window.zip 153k .zip file
The Excel sheet column A/B/C/D show the sizes, rest was just for calculation. Other file format or windows sizes needed please let me know.
best regards
post #127 of 273
Originally Posted by ndaa75 View Post
The 1% APL's on the GCD are not accurate and will give you a skewed picture.
Please clarify?
If different pattern size is required on gcd please let me know
post #128 of 273
Originally Posted by visca blaugrana View Post
Please clarify?
Visca,thanks for all your hard work on the GCD disc.
Would it be possible for you instead of using 1% pattern windows to use a 6.5% window sized patterns on GCD similar to what THX uses...The 6.5% window will give many of us 2011 Panny GT/VT30 a more accurate calibration.Thanks..
post #129 of 273
Please clarify?
Hi Visca
I've tried all patterns on both the GCD and AVS disks, the picture using the 1% APL on the GCD on my VT30 panny gave a result with severe posterization.
6.5% windows would be a great addition, perhaps with 1% windows as well ?
Edited by ndaa75 - 12/13/12 at 2:21pm
post #130 of 273
Hi Visca
I don't mean to discourage you, but I don't think you'll find a magic window size for a European VT30. It's very, very tough to get the NA VT30, when set to panel brightness low as the EU models are, to not show posterization. PB mid seems less prone to it, and it's possible with a lot of perseverance to get most of the posterization out when calibrated in mid.
post #131 of 273
Chad B.
On the North American VT50s, have you found a particular window size that works best????
post #132 of 273
Chad B.
I get beautiful results with no banding using conventional 5% windows.
post #133 of 273
I have a samsung pn51d6500 what window size do you recommend i use. I tried 10% APL from GCD. My gamma ended up being 2.21 avg.
post #134 of 273
When you say "conventional", I take that to mean that it's not an APL pattern, right?
Is this available on any of the disc that are floating around or did you have to make up your own set of patterns?
post #135 of 273
I haven't tried the GCD APL windows on a PN-D series yet, but from what I've read in the GCD thread it sounds like those patterns would do a great job.
The PN-E series ABL has surprising characteristics in that conventional 25% windows give a higher light output in comparison to 10% windows. This is the opposite of what you would expect if you're used to Kuro-like behavior, where larger window sizes reduce light output and round off the gamma at the high end, which is much more common.
If a plasma has a 10 point adjustment and if it has the more conventional ABL behavior, my opinion is that you should use either very small (my preference is in the 3-7% range) conventional windows that do not trigger the ABL (with contrast calibrated for no clipping or discoloration) or use APL windows that will load the ABL circuitry in an evenly controlled manner. What you don't want to do in that situation is use large conventional windows and try to compensate for the rounded off gamma with the 10 point adjustment.
If a plasma has unconventional ABL behavior as the PN-E series appears to, then larger conventional windows would most likely give better results than very small ones, with the APL windows also being a viable option.
You can test your PN-D series behavior by putting it in movie mode with cell light max, contrast high (near clipping point), and take a run with small windows and then large ones. If the large window results in a rounded gamma and less light output, then very small windows or APL windows is what I would recommend. If it shows PN-E like behavior, then medium to large windows (10-18%) or APL windows are what I would recommend.
post #136 of 273
Correct. My pattern generators have variable window sizes when used with CalMAN. I believe the CalMAN CalPC pattern generator does also.
post #137 of 273
I'll make some 4% (approx) .PNG window patterns for you and post them here.
post #138 of 273
If you're trying to author an image to video one possible complication might be Vegas converting the image to video levels. You don't say what levels you were expecting to represent black and white, but most likely an option to author images to video would cause a conversion to video levels. If your image was already in video levels, a modification intended to convert to video levels would mess things up.
To avoid moving between computer levels and video levels, we create video directly from images. Then we author that video to Blu-ray. That way we don't have to worry about how the authoring software tries to convert images to video levels, and it also allows us to use video levels that are darker than black or brighter than white.
The following two posts generally include our authoring process and the images we use to create video. Our images are setup to represent video levels, so that way we can show shades darker than black or brighter than white. Since the linked images are already setup for video levels, feeding them into a Blu-ray authoring program that tries to convert images to video levels would result in incorrect levels.
http://www.avsforum.com/avs-vb/showthread.php?p=16837914#post16837914
http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration/3390#post_22305141
Edited by alluringreality - 12/13/12 at 6:43pm
post #139 of 273
Here they are:
http://www.avsforum.com/t/1445226/chad-bs-custom-test-patterns
post #140 of 273
Dear alluringreality,
first of all thank You very much for the detailed explanation and the links which are a complete how to. Indeed this will help me creating my custom pattern disc.
That's clear the issue why my results messed up. I expect video levels, used Photoshop and video levels (black 16, white 235) for the images. Saved as .psd and imported directly into Sony Vegas.
Just to make sure, You used "MeGUI" for the MP4 files also? Would MPEG-4 AVC (x264) be the correct format?
Want to make MP4 files first because it's much more convenient for testing purposel instead of mastering blu-ray and burning discs.
post #141 of 273
Did You use 5% windows also for color?
post #142 of 273
Both the MP4 and Blu-ray files from our project were encoded using x264 and MeGUI. I haven't followed how x264 settings may have changed since our video was encoded, but the settings I used for 1080p video encoding are included at http://www.avsforum.com/t/948496/avs-hd-709-blu-ray-mp4-calibration/3180#post_21567091 Generally I don't follow this forum, yet if you run into encoding issues visca blaugrana may be able to help with the general process.
post #143 of 273
Hi Chad,
On plasma, Adusting WB control too much will likely cause more banding? The True Cinema preset' color temperature on my ST50 is ~ 5500, so I ended up did quite a bit of adjustment to get correct D65 and 2.2 gamma; using 10% ABL pattern. I do not notice any serious banding but not very sure about it.
post #144 of 273
Originally Posted by Light Illusion View Post
It is true that accurate plasmas calibration is all but impossible, due to ABL.
The best you can do is to gain an acceptable compromise.
There are different approaches to this, but getting the patch size correct from your particular display is critical.
Note: For Your Particular Display.
One approach is:
> Use a Grey-scale Ramp image - something like the attached.
> Then measure the overall brightness of the screen (with the probe covering all the screen - moving back and forward to get the peak reading).
> Just looking for Luma not colour readings.
> Then make a calibration patch window with 50% white and sized it to get a similar Luma reading with the probe in the same place.
> Use that patch size for the profiling (moving the probe to the correct distance for the patch size).
Also, the best results are often with a Quick Profile, not a full 3D cube profile.
Steve
I have a few questions regarding:
1. with the probe covering all the screen. What is meant here? Using a "non-contact" probe? or?
2. if not, then are you moving back from the display to get the Ypeak? Or, if in contact, moving to the part that is the brightest or just trying to pin the 50% middle and match it to a pattern size that provides a similar reading?
going to give it a try, but thougt I needed to understand a little better so I don't chase ghost too much. Sounds like an interesting method. What are some others?
T.
post #145 of 273
T.
here are the steps in detail as i understood them:
(1) Establishing Full Screen Probe Distance
> put up 100% white patch FULL SCREEN, establish probe distance from screen so u read the entire screen, moving the probe back and forward (towards / away from the screen), once peak luma value drops you are too far from the screen
(2) Get Peak Luma Greyscale
> with the probe in the same established position from step 1, put up greyscale ramp FULL SCREEN and note the peak luma value the reading gives you
(3) Establish Pattern Size
> with the probe in the same established position from step 1, put up 100% white patch and change the patch size to match the peak luma value from step 2
(4) Establishing Probe Distance For Custom Pattern Size
> move the probe closer to the screen (closer to the patch size established in step 3) until you get a peak reading, that means the probe is just reading the patch itself, nothing around it
==> that will be the final position of the probe along with that patch size
I tried this out yesterday night and on my VT50 plasma and it did not work... the i1D3 I used as a colorimeter is so unstable in it's readings (maybe it is the VT50 plasma ABL causing issues here) that the values u read (peak luma) change constantly...
if I would leave the probe in one position for 1-5 minutes (just for testing), the peak luma value would continuously start to DROP although the plasma is constantly displaying a 100% white and the probe was not moved...
when u try to establish the position of the probe in (1) where you compare peak luma values, this probe behavior makes this impossible as you move the probe around comparing bogus values to each other...
If anybody else tests this, please let me know your findings...
- M
post #146 of 273
Chad thanks for the tip about the e series and different window sizes issues( I wondered what size window to use).im Fortunate too see it as I don't look in the calibrating section often.That one tip will save me one heck of a lot of time and headaches.On certain middle to bright scenes with bright patches on it I'm getting all sorts of overbright brights in the bright patches and colors not right in the patches.I have a soft bright picture settings to avoid black crush...i dont have a meter.Hopefully this helps me.smile.gif
Edited by Vic12345 - 12/28/12 at 3:06am
post #147 of 273
One approach is:
Steve
Dear Steve!
Is a version with contact measurement ?
You can come up with something for contact measurements ?
with respect, Andrei.
Edited by anta1974 - 2/2/13 at 6:03am
post #148 of 273
It means that the probe or color meter is not touching or in "contact" with the screen use of a tripod is required. Contact mode is the oposite.
post #149 of 273
Not sure what you would get with this scenerio, but you could use a full ramp, as used above (which I think is intended to allow both a full rastered image, without tripping the ABL). Take some readings at some random points from dark to light (or use a ramp with known values) and do an average in contact mode, then use that data to figure out the "patch" and similar luma? Just babbling here, but it will probably accomplish a similar thing with a little more work. my 0.o2
post #150 of 273
Very thanx!
I did something like this as you said!
Once I made ​​smarter- I measured full fields (10% 20% 30% 40% 50% 60% 70% 80% 90% 100%) and received the average brightness!
got a very good result
my Panasonic VT50E
luma 21.51 cd/m2
Pattern 4.5% - 21.572 cd/m2
5% - 21.310 cd/m2
