Hey Guys/Gals
Since I couldn't find an intro section on this website, I just wanted to say that I'm a new member from Ottawa, Ontario. This is my first time getting into decent home theater equipment. I have spent probably over 30 hours reading in the last two weeks and have learned a lot about avr, projectors and screens. I was hesitant to make this thread because I don't want to repeat the same questions but I'm at a lost.
Previously I had been using LG 37 720P LCD and Logitech z-5500 speakers as a student.
Anyways that aside I have purchased a JVC DLA-HD250.
I'm looking for the following in a screen.
1) 110-120"
2) Solid substrate that is easy to acquire
3) I don't mind using a custom paint formula
Usage Scenarios: Basement room with 2 windows
1) Night time movie watching in darkness - should be very little ambient lights -40% Most important
2) Night time Video gaming - Willing to sacrifice some quality here- Willing to sacrifice some quality here
3) Evening/afternoon watching with some light from windows- 20% - this is the least important scenario
Room:
1) ~14ft x ~30
2) viewing distance I'll probably use SMPTE
3) I plan to add BOC to the windows
I read the DIY sticky but couldn't decide, I was recommended that I should go for a gray screen but what kind and what formula/substrate?
Thank you guys in advance
I'll get pictures of the space once I get a chance.
What I'm leaving behind
Pic of wall From seating position
Windows
Entire room
Dec 6th 2012
Added some fabric to the currently untreated wall. I can't tell if it made any difference. Maybe my eyes are just crappy. Still the room needs a lot of work. The carpet is very reflective.
Before fabric
Picture of Fabric
After fabric
December 16 2012 update
Monoprice mount was too small even though the specs made it look like it would be fine for this projector. So I had to macgyver a solution
Built a riser for the rear couch. Need to add carpet.
Final image size is 128"
December 19 2012 update
Before Sanding
After Sanding
Two coats of white paint
Cable management
January 5 2013 update
Final wall paint - two coats of RS-MaxxMudd LL
Two images with ambient light
Images with completely dark room. Pictures taken with a canon T2i with 18-55 kit lens. Automatic (flash-off mode)
Pictures of my summer toy
More screen caps in complete darkness
Final product
Paint supply list (CANADA)
Lowes
Rustoleum Metallic Accents - White Pearl - 30oz bottle $39.98
Minwax polycrylic Satin - 30Oz $18.67
3/16 Nap roller 1pc - $5.48
6" foam roller 2 pc - $6.58
Michael's
Liquitex Basics Silver $6.99/4 oz tube
Home depot
Behr 1750 (1850 replacement) $22 for 30 Oz
Final world
Pictures of final product have been uploaded. I have spent about 30 hours with the system playing games, watching movies and streaming TV. The picture quality has surpassed all my expectations. The experience is totally awesome and better than a movie theater and its all in my own house. I think the combination of my projector and RS-MaxxMudd LL is exceptional. The whole project was a joy to work on and definitely let me scratch my DIY itch,
The colours and black depth are much better than both of my old 720P LCD and 1080P plasma. I also just bought a new pn60e550 samsung plasma which has better blacks and more vibrant colours. But the difference in quality between the projector and the TV are not big enough to take anything away from the experience when switching from TV to projector.
I would whole heartedly recommend anyone to try out the RS-MaxxMudd LL or its other variants. I still have to do calibration on my projector and plasma but for now I am just enjoying both. I am also going to add one more run of black cloth to reduce affects of reflections from the side walls
Edited by fatestkid - 1/5/13 at 7:48pm
1) 110-120"
Room:
1) ~14ft x ~30
Windows
Entire room
Dec 6th 2012
Before fabric
Picture of Fabric
After fabric
Before Sanding
After Sanding
Cable management
Final product
Lowes
Michael's
Home depot
Final world
Well let's just say you could paint the ceiling and walls almost ANY flat "Cool" color that was significantly darker than beige and get much better results.
