As the title says really!
Just purchased an ex display pioneer htp 071 5.1 system and the reciever/amp keeps coming up with 'temp' on the display then turning the volume down by about 5.
I have the volume set at about 45 which is a good, not overly loud volume and it hold that for about 5 mins then turns it down.
Any ideas if its a setting I can change or a faulty unit?
