Hi so i took the plunge a few months ago to build my very first ht sub, i was using a in box home theater sub from my first system Onkyo this sub will now move to the room with its speaker and amp. I would like to thank Graham over at HT Shack for his help and the overall finish i took from Antti from Finland no pun intended. The overall size of the box is 26" x 26" 22" (660 x 660 x 559) and 5.6 cu ft. At this size it was designed for 20hz but Graham said i could get as low as 17-18hz. I also bought a Behringer EP2000 and a Reckhorn B2. On the EP2000 i done the fan mod which makes a world of a difference in the beginning my wife was like that is louder than your sub and its quite irritating now with it done we really enjoying the movies. I am running the sub off a Onkyo TX-NR708 and with Jamo S608 Hcs 3, a 5.1 for now but will be upgraded to a 7.2 once we return home.
With no further stalling here is the build:
I was excited to get my wood, but with us not having a car here in Geneva this was not a fun task to collect, luckily it was all cut so i used my trusty
IKEA trolley to bring the wood home.
My work station area well very small balcony
The brace
Just thought i will show my view from my work station
, it is Mont Blanc
Some more building and a bit that snapped on me while routing just glad it got stuck in the wood
I found this nifty dowel set and used it for my port lip instead of screw.
The port and the sign i got made for the sub end design, was measuring to see if it fits needed to drill holes in the back port board to get a flush mount.
Then a package arrived from the men in brown :-), nothing fancy like most of you guys but as this was my first DIY project did not want to spend to much and not be happy with the end project. O my soldering iron was broken so i improvised with my Creme Brulee torch it worked like a charm
Next step covering box in leather, when we get back home to S.A. i will buy a thicker leather as this is to thin and shows all the joints and lines.
More pics tomorrow
IKEA trolley to bring the wood home.My work station area well very small balcony
The brace
, it is Mont BlancSome more building and a bit that snapped on me while routing just glad it got stuck in the wood
More pics tomorrow
hope it works not sure but also then need to figure out how to use REW as well. I will check tomorrow in the day if i have any issues which movie did you use maybe i got it and scene.
