We recently moved to new home that has media room. I am looking for help on what projector to buy, what screen size etc. I read reviews of different projectors on projector central. Looked at different threads here.
The media room is pre-wired for 5.1 audio, a place for mounting projector, power supply for it etc.
The room is 12ft 10inches wide, 17ft long and ceiling is 8ft from flooring. There are no windows and room can be completely dark during day time if I close the door.
It looks like the projector would be 15.5 ft away from the screen. Using the screen size calculator on projector central, It seems 150" screen can be used (or > 135" screen can fit as well).
We are planning to use this mainly for viewing movies.
I am looking for a projector below $3K that can do excellent 2D and pretty good 3D. The reason I want 3D is because it is available and latest (It is probably < 5% of 3D watching compared to Movies).
Based on the reviews, Epson 5020UB seems like a pretty good candidate. I am open to suggestions.
If I go with a screen around 145" to 150", does it have enough juice to light up the screen that size?
My budget for screen is around $500.
Are there any decent screens in that price range?
I already have Bose audio system that can do 5.1 audio (the one with those speaker cubes). I am planning to use it in this room.
I appreciate if you can point me to good dvd player that can do 3D, upscaling and BD playing.
I see some at local Costco. Are they good?
I am looking for suggestions, what not to do and what are things that new-bees overlook?
Joe
Joe
In the world of front projection (IMO) SIZE MATTERS. Get the biggest damned screen you can.
I'm running about 187-inch diagonal in a light-controlled room with an Epson 3010 at the moment and it's PLENTY bright. Even quite watchable with 3D (despite the loss in brightness because of shutter glasses.) As in a movie theater, I DON'T WANT to see the entire picture at once. Having a bit of the image in my peripheral vision adds to the immersiveness of the experience, at least for me. However, if you DON'T have effective light control in the room, you may want to go with a smaller screen size to optimize the brightness for your situation.
