Originally Posted by boblinds
Techmine:
Sorry I didn't respond sooner, I've been away. I don't think you need to get heartburn. It's a very nice HT room. The high ceiling is great. I'd just get some blackout curtains and give it a go without repainting the ceiling. Or temporarily cover the window with newspaper for testing purposes. It will also block the light and have the added benefit of making the neighbors think you're setting up a crack house.
Also, if you're concerned about having a long dropdown attachment to a ceiling mount, perhaps you could just mount the projector to the opposite wall with a kind of shelf mount. I'm sure someone here has experience with that kind of installation and could offer some suggestions.
A lot of us have converted our home theater enthusiasm into a hobby/obsession, so we might tend to make these things seem more complicated than they are (in our quest for anal-retentive perfection.) In fact, setting up a projector these days isn't much more complicated than setting up an old slide projector. Just experiment a bit with placement before you lock in your final installation.
Techmine:
Thanks for your comforting comments :-)
Did exactly that. Bought extension type mount and works work and I get to keep my fan in place :-)
Curtains are on their way. Tested in dark conditions and its all good. I agree with you, the current generation PJs provide so much flexibility in placement.
I have posted my first had experience. Feedback welcome!
