AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Pioneer VSX-921 speaker output problem
post #1 of 3
I have hooked my system up, did the balance test ,which worked beautifully, and now all I get is front l/r and sub. I'm sure it is a simple click of a button to fix but I can't figure out which button.
Thanks in advance.
Dobber
post #2 of 3
I assume you have 5.1 or 7.1 connected? What source are you playing from and what does the front panel of the receiver indicate?
post #3 of 3
Yes it is 7.1 but I am running it for now with 5 + sub speakers. The display shows TV/Sat, phase auto top left, sp>A mid right, 01 right, lower right digital.
