AVS › AVS Forum › Other Areas of Interest › Camcorders › What camcorder should I get?
post #1 of 12
Hey guys! I'm really just posting this to get help assessing my options I need to buy a camcorder for the documentary class I'm about to take at my local community college. I'm a junior in high school but I've already decided that after senior year I'm going to take a sabbatical and go to the Gaza Strip, Libya, Syria, Mali, The Korengal, etc to either photograph or film the various conflicts in that area.
Unfortunately I probably wont have enough $$$ to buy plane tickets an apartment, and buy another camera so the one I buy now will have to do. I was going to buy the Sony HVR Z1 until I learned its been discontinued. How are the Z5's and Z7's?
I need something rugged, reliable, HD, low light capable, and light enough to run through a battle field with wink.gif
post #2 of 12
Anyone?
post #3 of 12
Any reason for preferring a tape-based camcorder?
post #4 of 12
If you're going to be in the desert, consider a dustproof (and rainproof) camcorder:
http://www.bhphotovideo.com/c/product/761581-REG/Sony_HXR_NX70U_HXR_NX70_Compact_Dust_and.html
I don't know if you are going to be near actual fighting, maybe also consider having a point--of-view camcorder on you that you can just wear:
http://www.bhphotovideo.com/c/search?Ntt=point+of+view+camcorder&N=0&InitialSearch=yes&sts=ma&Top+Nav-Search=
Will you be running and pointing a hand-held camera might not be an option(?) Any footage/better than no footage.
Or perhaps look for a mega-zoom camera and stay as far away as possible. biggrin.gif
post #5 of 12
Take a look at Sonys' GW77.
post #6 of 12
That is exactly what I would buy to run through a dusty desert battlefield. Not only is it rugged and dust proof, it has enough "incognito" factor to aid in avoiding being a target! The price might be a little closer to a students budget too.
Bill
post #7 of 12
Haha! That might be a good idea! I'm planning on having a GoPro HERO3 Black on a head or chest mount in case I neeed to turn off my other camera.
No. I suggested those cameras because they used a Z1 to film Restrepo. Although one of them died while filming in Libya, so this might be one of my worst ideas ever...
Bill
I'm not trying to win Sundance with this but, I'd like to make something I can turn into a low budget film, so if that is a good camera disguised as a flip I will definitely buy it. Also, I was reading some guidelines for journalists and standard procedure in a war zone is to jump behind cover and hold your camera up if you come under fire. I'd like to have something easy to spot...biggrin.gif
post #8 of 12
Thanks again guys!
Edited by SuperTaxi - 11/27/12 at 12:00pm
post #9 of 12
Bill
yeah ...great imago quality and rugged. I was going for OP's price point as it looked like he wanted a more serious camcorder for documentaries.
I don't know how it works out there, maybe having a larger camcorder would designate you more as "neutral" media.
I certainly wouldn't get the black GW77, as it may be mistaken for a pistol....
post #10 of 12
But the bright blue one can be more easily spotted by snipers...
post #11 of 12
heh-heh
post #12 of 12
For days in the rain and mud I take a Kodak PlaySport Zx3 and 5 extra (aftermarket) batteries. Otherwise it serves as a quick out of the pocket camcorder and backup. The later Zx5 model is stuck with a built-in battery so avoid.
http://www.amazon.com/Kodak-PlaySport-Waterproof-Pocket-Camera/dp/B0030MITDK/
  Back to Forum: Camcorders
