AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Harmony One ans Denon AVR 2112ci issue.
post #1 of 6
Guys,
My Pioneer vsx-1120 blew out yesterday which knocked out my living room projector and plasma tv so I needed an emergency replacement. I was able to pick-up a Denon AVR-2112ci for $300. The catch was it was an open box and did not come with anything except the receiver itself. I figured no biggie since I have 2 Harmony one remotes. problem is after programming the remote I cannot navigate up or down when in the menu. Left and right work fine but I cannot setup the receiver to work correctly. Is anyne else using a Harmony one and if so can you navigate the osd menus? Any and all ideas will be appreciated.
post #2 of 6
I'm using a harmony one and it works fine... Did you download the latest software? Select the right receiver etc?
post #3 of 6
Yes and Yes
What features I can use work. Like volume input, mute etc. I just cant navigate up and down within the on-screen menu.
post #4 of 6
Hi Rudmeister, in the remote setup program you need to add "Direction Up" and "Direction Down" under customize buttons menu in either the "Standard Buttons" or Additional Buttons".
Go Devices -> Select AVR-2112ci -> Settings -> Customize Buttons -> then add it to either (Standard or Additional)
post #5 of 6
Adding to JChin's post, the commands are already in the database they just aren't assigned correctly. Follow the path above and scroll down in the standard buttons. You will see the UP/Down buttons are probably assigned "TUNE UP / TUNE DOWN". Change those to DIRECTION UP/DIRECTION DOWN, save and update.
post #6 of 6
Thanks guys. That's exactly what it was. The up/down was assisgned tune up/down. I changed it and it works fine now.
  Back to Forum: Remote Control Area
