AVS › AVS Forum › Audio › DIY Speakers and Subs › new Lab12C
new Lab12C
post #1 of 7
http://www.parts-express.com/pe/pshowdetl.cfm?&Partnumber=290-668&scqty=1
Same great driver now available in 4 ohm load.
Not even compared parameters yet.
post #2 of 7
An odd duck, actually, as the standard LAB 12 is six ohms. I'm surprised they brought this out.
post #3 of 7
Squeeze out some extra sensitivity to compete with newer bass designs maybe?
post #4 of 7
It's only a 2dB difference, and that's only of value if your amp is too small to drive the 6 ohm to full output.
post #5 of 7
I have a standard 6Ohm lab in a small sealed box for the garage. 1.2cu ft sealed powered by a bash300.
I'm not very good with winISD but this C driver models less?
post #6 of 7
If you let WinISD calculate the default cab size the 4 ohm gives a smaller box size than the 6 ohm, but with a higher F3, so you're not really gaining anything.
post #7 of 7
Thanks Bill that's kinda what I was seeing, and no real gain. Strange indeed this driver is biggrin.gif
