AVS › AVS Forum › Display Devices › Display Calibration › What X-Rite to get in 2012
post #1 of 21
First of all I want to tell you that I'm new in the "calibrating display world", so bare with me smile.gif
Im currently reading "GREYSCALE & COLOUR CALIBRATION FOR DUMMIES" after I got my Benq W1200 and want to calibrate it.
I can see that the Thread is written in 2006. My question is:
Are the eye-one and spider still the recommended Meters to buy? - or are there newer ones in the same pricerange which I should by instead, now that we are in year 2012 ?
Which Meters would You suggest that I go for?
Thanks in advance
//Stefan Knudsen
post #2 of 21
You have a few choices for new meters today:
- X-Rite Display3 OEM ($249-299) will need software, CalMAN, ChromaPure, HCFR
- X-Rite Display3 Retail ($249) works with CalMAN
- X-Rite i1Pro2 ($1200) works with CalMAN, ChromaPure, HCFR
- SpectraCal C3 ($149) includes a copy of CalMAN 5 Tutorial
- SpectraCal C6 ($695) works with CalMAN 5 Control and Enthusist
Both the C3 and C6 are built for us by X-Rite.
Edited by derekjsmith - 11/27/12 at 12:58pm
post #3 of 21
Thanks alot for the fast reply.
I think I will go for the X-Rite display3
I can only find it on the link below.
http://www.chromapure.com/products-d3.asp
Where else can I get this from (Im from Denmark in Europe) , european link would be appeciated.
Thanks in advance
post #4 of 21
Thanks in advance
One option is to buy the Display3 Retail locally and just add CalMAN 5.
post #5 of 21
Thanks in advance
//Stefan Knudsen
Before getting too far into this, you need to know that for a variety of reasons, you are going to want a spectro to profile the i1display3 with.
Many of us entheusiast use a i1pro2 that's about $1K. You can find used i1pro (an earlier model) for less but if you're the least OCD, you'll always wonder how accurate it is.
post #6 of 21
Another option would be to buy in the UK
http://www.chromapure.co.uk/products.asp?page=1&cat1=37
post #7 of 21
Thanks in advance
The i1Display Pro, which is only another name of the same item will sell by amazon.de for 160 Euro and also at ebay.de are a lot of offers.
post #8 of 21
Amazon.de Sell's the Retail Version of the Meter, you need CalMAN for that, ChromaPure is supporting the OEM version of the meter.
post #9 of 21
That´s right and mentioned above in the thread by Derek. But Stefan has not decided which software he will use or I have missed this?
This restriction is the reason, why I not thinking about buying Chromapure and also that I need to buy a second license, if I want to profile the i1Display pro with the i1Pro.
post #10 of 21
http://www.grafisk-handel.dk/shop/x-rite-i1display-pro-4877p.html
This will work with hcfr and CALman
post #11 of 21
Can someone point me in the direction of a thread that explains profiling.
post #12 of 21
This is a great paper on it:
http://www.spectracal.com/downloads/files/Website/Website%20Articles/Four-Color%20Matrix%20Method%2011-08-10.pdf
post #13 of 21
Hi guys
Appreciate all the answers that I have gotten, I really do. Cause as I said, I'm still a newbie in the calibrating world.
What kind of tripod fits the i1Display Pro?
Or am I able to just use like a Microphone Tripod which I can get from my workplace?
Thanks in advance, and I appreciate your time/help you are supporting me with.
//Stefan
post #14 of 21
Regarding what software to use, I actually don't know yet since, the only thing I have read is the "GREYSCALE & COLOUR CALIBRATION FOR DUMMIES" located on this forum.
I might be using the software he is using or what would you suggest ?
post #15 of 21
standard camera tripod.
post #16 of 21
Most mike stands use 5/8-27 threaded adapters. the i1Display Pro usee 1/4-20.
post #17 of 21
Places like Guitar Center and Musician's Friend sell inexpensive camera-thread adapters to mount on mic stands. I use one on mine when I'm doing Audyssey measurements.smile.gif
post #18 of 21
This OEM version - does it still work with computer monitors and laptops??? Or is it now "locked" to doing projector calibration with Chromapure?
post #19 of 21
The OEM doesn't work with the X-Rite software for doing PC calibration. Many 3rd party providers support the i1 Display Pro OEM meter for PC calibration including CalMAN.
post #20 of 21
This is important to know. Which 3rd party support Mac OS X with the OEM????
post #21 of 21
CalPC
DispcalGUI
basICColor display 5
all work
