All,
I am having an issue getting my AppleTV to display through my RX-A810 although if I bypass the receiver the display locks just fine. I can display 1080P images from my blu-ray player, 1080i and 720p from DirecTV, 1080i from Windows Media Center through my RX-A810, etc. But when I try AppleTV at 1080p, 720p even 480i, the image doesn't lock. When I run direct to my TV (LC80LE844U 80-inch 3D LED TV) it works fine. I have tried different HDMI cables as well.
The only wrinkle is everything is going through HDBaseT extenders (http://www.accellcables.com/products/switchSplitter/HDMICat5eHDBaseT/HDMI_Cat5_HDBaseT.htm) and an HDMI Matrix Switch ( http://www.snapav.com/p-1073-b-100-hdmatrix-8x8.aspx ). But that is the same way all my other signals are routed with no issue and AppleTV through HDMI Matrix and HDBase works direct to the TV and also with a Pioneer VSX-1020 setup in the bedroom. I have played around with learning EDID settings from working components on the switch with no luck. I have also tried plugging in the appletv into the same input that works for DirecTV and that didn't work either.
Going to try HDMI out 2 tonight (just thought of that) and try to see if I can get it to work in power off pass through. I'll also try to bring the AppleTV in the room to cut out the HDBaseT/HDMI matrix.
Last thing is this DID work several months ago when I moved into the house and set everything up and wonder if an AppleTV update changed anything. The RX-A810 firmware is up to date and hasn't changed since I set the system up.
Any ideas?
Dan
Any ideas?
Dan
