I recently purchased a SR6007 and i love the sound and it looks great too
here's my problem with it..........
it will freeze up, by that i mean you cant adjust the volume up or down,
manually or remotely or even turn it off without unplugging it
the music still plays, the picture still shows
this happens with music, tv, blu ray, aux, it may play fine for 3-4,5 hours
or as little as 30 minutes and freeze up or it can go several days without a problem.
I have reset microprocessor, got firmware update and still the same
It's in a well ventilated spot......65degrees in the room the temp off the top of the recv is 90-96 degrees......
is that about right?
Any ideas on how to fix this, i sure hate to undo all those wires to send it back
Thanks guys
Thanks guys
