AVS › AVS Forum › Video Components › Home Theater Computers › Anyone have experience with this HTPC case XON-710P_BK Black Steel Micro ATX / Mini ITX Slim Desktop Computer Case 300W Power Supply $39.99 ????
Anyone have experience with this HTPC case XON-710P_BK Black Steel Micro ATX / Mini ITX Slim...
post #1 of 16
post #2 of 16
I think you will have trouble finding a replacement for the PSU because of the power plug placement. If the PSU works, it looks like an amazing price for a micro ATX case with PSU. Even comes with card reader.
post #3 of 16
Yeah.. it's not for me. It would be bricked if the PSU died probably. It's for a cheapo build for a friend to surf on his tv using old parts.
post #4 of 16
I just recently purchased a couple of these cases. I did not realize the power supply issue until I opened the case.
I have contacted Xion Support and am waiting for a response as to how to replace the power supply.
If I get an answer I will let you know.
Also, the case is pretty nice. Holds a full size optical drive and one 3.5" HDD. Has two front 2.0 USB and one SD port on Front Panel.
Since it is made of steel, it has a nice "solid" feel to it. The panel is glossy and looks nice. It also comes with two "feet" to stand it up on its side so you do not have to keep it flat.
Aside from the power supply issue, I am pleased with this case.
Edited by Barbara Parry - 1/16/13 at 8:53am
post #5 of 16
Why not replace it with a picoPSU?
post #6 of 16
not sure this is what you are referring to or not. I found this last night:
Product Code: PP-450ROF
So YIPPIE!!! Found one!
BTW....Xon support has yet to email back [over 48 hours now, and their customer service number does not work].
post #7 of 16
Just curious, why are you replacing the PSU? Why not just buy a difference case to start with?
BTW, I think the PSU is a SFX/micro-ATX, the cable is a little hard to come by. But if you don't mind the the hole left behind, can't you replace it with a standard PSU and just run the power wire directly to the PSU from the bottom? You may need a right angle PSU cable if you need the case upright though.
post #8 of 16
http://www.in4dealz.com/deals/UHost-U1A-Mini-PC-Google-Android-4-0-TV-BOX-Allwinner-A10-1Ghz1GB-DDR3-4G-Storage-Built-in-Mic-600173/
post #9 of 16
post #10 of 16
Why replace the PSU ????
post #11 of 16
What is this ??
It's a mini box android stick. Plug it into TVs HDMI slot and give it USB power (from TV if it has a USB port for F/W)
Runs android, can surf the web for $30
post #12 of 16
I don't wanna surf web I want to stream media content from my server
post #13 of 16
It can do some of that very well, if you'll trade off for plex transcoded quality or wait for the Android version XBMC Frodo to get H/W support
Really, I was responding to post 3 of this thread. I thought it was for a different purpose, for now Android still isn't up to snuff at media streaming locally stored blu ray rips at full quality
post #14 of 16
I'm interested in getting a cheap extender for my basement so wife can watch on treadmill.
I need extender under $100.
post #15 of 16
Must be simple use and slick.
post #16 of 16
this case would be a nice extender machine I think... with a g530 like cpu
