I'm in the process of converting a closet (under the stairs) to an equipment closet. I've only put in one server and a UPS and it's already getting too hot so I need to devise a cooling solution. I was wondering what you guys recommend.
I can run an HVAC return from the closet to my return plenum. The problem I'm thinking of with that is that the AC will only turn on intermittently giving plenty of time for temperatures to rise.
I saw this in another thread by cheezit73 where he put in fans to suck air out. I could use either that or the bathroom vent vans recommended.
Return
What would be the optimal way to exhaust? HVAC Return? Jumper (w/fans) to next room. HVAC Return w/fans (would that cause problems on the HVAC heating up).
Supply
Also regarding air pressure issues , I don't want to cut the door (keep fan noise inside the closet) but could run a supply line from the AC or cut a hole in the stairs and put a vent there
Return
Supply
