Just having a thought today about 4K and the future generally; I'm sure that at some point I will own a 4K projector so just thinking ahead to some degree. I have an older Isco II lens which I guess might not be up to using with a 4K projector (or maybe even an Eshift one). I'm about to get a new JVC X35, but also thinking that an X55 without lens might be another option.
In my set up I'm at the absolute minimum zoom with my current HD350 (RS10) so getting least brightness from the projector. I've measured the lux output when using the lens to fill my 2.35:1 screen and also when zooming to fill the same screen, I get near enough the same result. So for me there isn't the gain in brightness that many lens users have, possibly due to the rapid change in aperture of the projector's lens from minimum zoom to 1.33x zoom. I also own a Lumagen Mini3D video processor and I am familiar with using the 'shrink' method having done this previously before I got my lens.
So I'm considering the following for going with the Eshift option, given that I wouldn't gain or lose brightness either way. My Isco II is on a stand, so I only put it in place for 2.35:1 content (H squeeze just for the trailers and menus) and don't use it at all for 16:9 content which means adjusting the projector's zoom, focus and shift as the Isco II magnifies the image height by approx 5%. I have some minor peculiarities with my particular set up which may also be improved by the X55 option.
Postives over existing HD350 plus Isco II set up:
If I went to an Eshift model I would have more pixels on the 2.35:1 screen when zooming than I do now with the HD350 plus lens, so I'd have a higher pixel density than now.
The X55 has 5 lens memories which will save the need to have to adjust the zoom, focus and shift when removing my Isco II lens for 16:9 content.
The floating shelf for the projector I'm building won't need to be so deep with the lens.
The image will no longer be too big for the screen I have due to the slightly long throw distance (the Lumagen is used to trim about 2-3" off each side and a fraction off the top and bottom).
No pincushion at all (though it's very minor anyway).
Sell the A lens while there are still buyers who want one.
Negatives:
More money than X35 plus keeping the Isco II.
Overspill of black bars ( I'll be building new screen pelmet so this could have black velvet borders to null this effect).
Frequent zooming may wear the mechanism out sooner, though plan would be to use 'shrink' setting on Lumagen for 16:9 menus, trailers and 'after film' TV broadcast material when the 'main feature' is 2.35:1, so I'd only use 1:1 pixel mapped 16:9 (ie use the 'other' lens memory) for 1.85/1.78:1 BluRays.
No longer in the A lens club and have to change my signature.
Any thoughts or has anyone done a similar change? It isn't an option to keep the Isco II and buy an X55 before anyone suggests it: I already have a better CMS in my Lumagen, so it's hard enough to justify the extra cost as it is.
I already have a Darbee device too, which works well with my existing set up, presume it would work well with the X55 too judging by other RS55 + Darbee owner's comments.
Edited by Kelvin1965S - 11/28/12 at 1:36pm
Negatives:
I already have a Darbee device too, which works well with my existing set up, presume it would work well with the X55 too judging by other RS55 + Darbee owner's comments.Edited by Kelvin1965S - 11/28/12 at 1:36pm
. Especially since you are already scaling (1080p) anyway.
I had lent him my lens as he wanted to compare the Sony plus lens against the X55 without, but I couldn't make it due to my London weekend unless I got back in time. I'll probably have to arrange later this week or maybe next weekend if he has a slot.
