AVS › AVS Forum › Display Devices › LCD Flat Panel Displays › Samsung UN55ES7003 - Turning Off SyncPlus isn't Sticky
post #1 of 4
Further to this thread it appears that when I turn off SyncPlus the setting is not "sticky". What I mean is, after turning off the TV and then back on, the setting returns to 'On' and I have to go back into Smart Hub and turn it to 'Off' again.
How can I disable SyncPlus so that it stays off?
post #2 of 4
Uncheck the terms and conditions box for SyncPlus (same place you turned it off).
post #3 of 4
Again, fantastic. Thanks for the help!
post #4 of 4
Hi. I can turn off the T&C for SyncPlus, but I don't know how to actually disable it. Can someone please help. Thanks.
