AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › did my ps3 die?
did my ps3 die?
post #1 of 11
I was hoping i could get some help from the avs before i start searching around the internet. So i was playing black ops today when suddenly the ps3 (not slim model an old one) suddenly shut off and the red light was flashing after waiting a minute i hit the button and the light stopped flashing red and went steady red. After that i attempted to turn on again... it turned on for a quick second then went back to flashing red with nothing appearing on screen, any help or advice, thanks fellas!
post #2 of 11
Reflow or sell it. A reflow (do a google search) will only delay the inevitable, but it might let you rescue your saves if you haven't backed them up recently.
The old phat PS3's are ticking time bombs. They aren't built to last and started dropping like flies over the last couple years. I'd sell it ASAP (even if it's not working, people will pay decently for the old PS3s). Then I'd buy a newer model. So far so good on these newer ones. *fingers crossed*
post #3 of 11
if i buy a new one is there anyway i can transfer the data from the old dead to the new one?
post #4 of 11
Not a dead one, no.
post #5 of 11
http://www.avsforum.com/t/1353745/if-you-have-a-phat-sell-it-a-warning-from-refurb-land
post #6 of 11
The old PS3s are reliable as you can expect from electronics these days. Mine's 4 and a half years old and still working like a champ. And between games and Netflix, it gets used plenty.
post #7 of 11
Hope you keep it backed up, because it will die. Probably sooner than later.
post #8 of 11
You're one of the lucky few. I'd wager that most of us early adopters here have long since replaced our phat PS3s.
post #9 of 11
My 80GB PS3 "phat" is still working perfectly fine without issue. Have their been any type of statistics that shows rather people constantly using Folding@Home decreases the longevity of the PS3 compared to people who either hardly or never use it?
post #10 of 11
My January '07 built 60G is still working just fine. I take it apart and blow out the dust bunnies every year or so. I have PS+ so my saves are backed up just in case.
post #11 of 11
Go check out a breakdown vid and take a look at the cooling system of the Phat PS3. Then realize they frequently are putting out 100C+, hotter than most gaming laptops.
With the tin solder problems, it'll fail eventually. If there's a trade in deal that makes a new system cost about as much as a crappy refurb, I HIGHLY suggest you take it.
From a guy thats gone through 2 PS3's and very expensive SXRD Sony television in just the past 5 years. Sony hardware QA from 07-08 crap.
  Back to Forum: PlayStation Area
