I just bought the Panasonic SC-BTT190 HTIB since it was a good deal. I had assumed that even though it only had one HDMI input I could just hook it up to my TV and use my TV as the hub for all my other devices. Well I guess I didn't quite do my research and really I can only connect one device which makes absolutely no sense to me. I was hoping to connect my cable box and my Xbox 360 to it without any switches or splitters. I already know a Toslink splitter won't work because even when my cable box is off it still sends a signal through the cable. I don't really want to get a switch and have to turn a dial to switch connections. Is there any other method of connections I can try? If the only solution is getting a switch then I might just try to return it and get a regular receiver with speakers that actually has all the inputs I need.
AVS › AVS Forum › Audio › Home Theater In A Box › Connecting multiple devices via one HDMI input and one Optical
AVS Top Picks
post #3 of 5
11/30/12 at 12:39pm
post #4 of 5
11/30/12 at 1:45pm
post #5 of 5
11/30/12 at 4:02pm
AVS Top Picks
