AVS › AVS Forum › Audio › Soundbars › Can I use the TV remote to adjust the sound on this sound bar?
post #1 of 2
http://www.amazon.com/Yamaha-ATS-1010BL-Factory-Refurbished-Surround/dp/B0077HED8O/ref=cm_cr_pr_product_top
After I plug this in with the optical cable that's provided, will I be able to adjust the volume up and down with my Comcast remote that controls the audio on the television? I just want to make sure before I buy it. Many many thanks. :-)
post #2 of 2
Very doubtful. You would probably need a programmable universal remote like a Logitech. It was a Yamaha YSP that lead me to get my first Harmony remote in 2007. The remote was a better purchase than the soundbar.
  Back to Forum: Soundbars
